With the engine off and the key at the accessory position, have a look at the light. To show it's working, it should flick once when you turn the key to accessory. If the light is flashing, it means there is a trouble code, to determine which one, count the length and number of flashes.A long flash indicates tens and a short flash indicates ones, so one long flash will mean code 10 and one fast flash shows code 1.
For example: Flaaaaaash Flaaaaaash Flash = code 21
Flaaaaaash Flash Flash = code 12
Flash Flash Flash = code 3
To find out what each code means, please check below:
1) Primary oxygen sensor- Defective circuit or unplugged/ Defective sensor
2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor
3) MAP (Manifold Absolute Pressure) Sensor - Defective circuit or unplugged/ Sensor
4) CKP (Crankshaft Position Sensor) - Defective circuit or unplugged/ Defective sensor
5) MAP (Manifold Absolute Pressure) sensor -Mechanical problem/ Disconnected piping
6) ECT ( Engine Coolant Temperature) Sensor- Defective circuit or unplugged/ Sensor
7) TP (Throttle Position) Sensor -Defective circuit or unplugged/ Defective sensor
8) TDC (Top Dead Centre) Sensor -Defective circuit or unplugged/ Defective sensor
9) CYP (Cylinder) - Defective circuit or unplugged/ Defective sensor
10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor
12) EGR (Exhaust Gas Recirculation) -Defective circuit or unplugged/ Defective sensor
13) Atmospheric Pressure Sensor - Defective circuit or unplugged/ Defective sensor
14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor
15) Ignition Output Signal - Missing or defective ignition output signal
16) Fuel Injector System - Defective circuit or unplugged/ Defective fuel injector
17) VSS (Vehicle Speed Sensor) - Defective circuit or unplugged/ Defective sensor
19) Automatic transmission lockup control Solenoid Valve- Defective circuit or unplugged/ Defective solenoid. A/T Only.
20) Electronic Load Detector - Defective circuit or unplugged/ Defective sensor
21) VTEC Solenoid Valve- Defective circuit or unplugged/ Defective solenoid
22) VTEC Oil Pressure Switch - Defective circuit or unplugged/ Defective switch
23) Knock Sensor - Defective circuit or unplugged / Defective sensor
30) Automatic Transmission Signal- Defective circuit or unplugged/ Defective sensor
31) Automatic Transmission Signal "B"- Defective circuit or unplugged/ Defective sensor
41) Primary Oxygen Sensor Heater- Circiut malfunction
43) Fuel Supply System - Defective or malfunctioning Fuel Supply Sytem
45) System too lean or too rich - Malfunction in the fuel monitoring systems
48) LAF (Lean Air Fuel) sensor - Defective circuit or unplugged / Defective sensor
54) CKF (Crankshaft Speed Fluctuation) sensor- Defective circuit or unplugged / Defective sensor
61) Primary Oxygen sensor circuit- High/ Low Voltage, Or slow response
63) Secondary Oxygen Sensor circuit- High/ Low Voltage, Or slow response
67) Catalyst System Efficiency Below Threshold- Malfunctioning catalyst system
70) Automatic Transmission - Malfunction with Automatic Transmission Controls
71-74) Random misfire in Cylinders 1-4- Condition present Creating Misfire
80) EGR (Exhaust Gas Recirculation) Insufficient Flow Detected
86) ECT (Engine Coolant Temperature) Circuir Range / Performance Problem
90) Evaporative Emissions Contrlo System - Leak Detected In Fuel Tank Area
91) Fuel Tank Pressure Sensor- Low Input
92) Evaporative Emission Control System Control System- Insufficient Purge Flow
Hope will help you to solve your engine problem... :D :rolleyes: :lol: B)
