accelaration problem
apexi_88
dear all sifus..
1)sometimes when i'm accelerating my car i feel like the car is going slowly (like something pull back behind) then suddenly the car goes back to normal and accelerates fast... why this happen??
2)my engine is consuming engine oil now....so what is the diff if i'm using 15w/40 mineral and 10w/40 semi syn??
Tq all sifus in advanced....
i would go with wat the factory suggested oil. old oil does play lots of difference at least for me i can feel them
apexi_88 said:
dear all sifus..
1. a. Maybe your intake it more than output. May I know what is the modification that u had been done, such like air filter, extractor, piping how many inch, etc etc....
b. If your car is Turbo, or Supercharge. This will happen when using the lousy clutch plate, which mean not suit for turbo car usage.
2. What engine?
a. 4AGE, 4E recomended using the 10w50 or 15w50. These I tested with the Oil Press, Oil Temp, and Water Temp, and seem that 4AGE very suit with 10w50 or 15w50.
b. 3SGTE recomended using the 10W50, 15W50 and 10W60.
c. If normal engine, 4AFE, 7AFE, 2E and etc etc... much recomended for 15W50 and 20W50 lor....
Note: the 10W,15W, 20W is actualy is the measurement about the "kelikatan" when it at extreamly HOT
The behind 40, 50, 60 digit is the measuremend for ketahanan haba... 40 is only 80-110 celcius... 50 is 110-140 celcius, and 60 is 140 celcius and above... Mean the more at the behind the more the heat can be stand.
ops forgot to mention engine vy sorry.
I'm driving SEG with 4age svt, light modi with intake simota open pod filter and 2" piping straight flow muffler (5" tail pipe)
Tq for sifus' reply
Tq for sifus' reply
Intake Simota and 2" Piping... I don't think got problem....
what clutch u using?
If you for better respone and power torque... I suggest you go to do engine balancing...
U may have an out-setting TPS.
Some mech like to adj the TPS in order to compensate the idling problem of SVT that was actually due to dirty ITB and clogging ISCV.
levin818 - just curios...ISCV valve is the one with two screws and yelloswish palstic cover right...??? how to clean it...can DIY aaa ???
tps
maybe sifu wong can guide abit on how to check or adjust the TPS...
dun la point to service manual..i got one..also dun really understand...
thanx
oit sifoo zul...
ISCV the one u adjust for mee aaaa...
making idling to 1k...
Sifu levin818,
how to set the right TPS?? pls help....
