ABS Problem
wild_boost
Car Model: EK 1996 ,Single cam V-Tec
Dear All.
My friend car had a problem recently with his ABS system.
ABS indicator is ON and OFF. It is not blinking but ON for a few minutes and\
OFF.What matter him is the braking is worst. When he applied brake, the is a vibration
on his right tyre. This is happen a few time and not all the time.
Checked already for any mechanical fault at caliper and sorrunding area but showing none...
Pump servo changed but problem still occuring(the vibration).
The mechanic suspect the hydraulic unit ( square unit under pump servo with pipe tube)
is main problem.The is no leaking on it.Pening liowww......
Anyone face the same problem b4?
Pls advise me..
Thanks.
have yu chech the disk .. mebe bengkok
if the probelm still there, just take it out laa
i think faulty on the abs main unit (square one)... HSC told me its a common problem... ekekkeke...
try to send ur car to HSC to verify the problem. diagnose will cost u around RM60. thats for their air liur only.
the ABS sensor on the wheel spoilt/no function...check it out
diagnose only is RM 60??? . WTF.!!!!:eek: .....vampire ke??
BTW u know any workshop at PJ can repair this problem??
workshop at pj dunno but u can try to go HSC at pj, next to the philips service center...
but the price.... eheemmmmm....
ABS code....
Maybe you can try this to diagnostic by yourself...
Honda ALB2 ABS computer - fault codes.
Fault codes: how to access. Turn igniton off. Bridge diagnostic socket terminals. Turn ignition on. If ecu is ok warning should come on for 2 seconds and then go out for 2 seconds. The lamp should then begin to flash. The first set of short flashes indicate the first number of the fault code. A brief pause seperates each flash. A medium pause seperates each group of flashes. If there are more than one code stored a long pause seperates each trouble code.
Code Fault
1 Hydraulic pump motor over-run
1/2 Hydraulic pump motor
1/3 High pressure leak (possibly modulator)
1/4 Pressure switch
1/8 Pressure accumulator
2/1 Handbrake warning lamp switch circuit faulty
3/1 Right hand front rotor damage
3/2 Left hand front rotor damage
3/4 Right hand rear rotor damage
3/8 Left hand rear rotor damage
3/12 Different tyre sizes fitted
4/1 Right hand front wheel sensor
4/2 Left hand front wheel sensor
4/4 Right hand rear wheel sensor
4/8 Left hand rear wheel sensor
5/4 Right hand rear wheel lock
5/8 Left hand rear wheel lock
6/1 Front fail safe relay
6/4 Rear fail safe relay
7/1 Right hand front modulator solenoid valve
7/2 Left hand front modulator solenoid valve
8/1 ABS operation fault
8/2 Electronic control unit (ECU) fault
8/4 Electronic control unit (ECU) - internal circuit fault
Good luck
A
Replies
7
Views
2K
achor
A
