Hi all.. I'm a new member and need some information on the differences between these two engines in a Cefiro A31..Please feel free to share your knowledge..
The main areas are..
The Engine, gearbox, Differential, prop shaft, rear suspension, rear knuckles, drive shafts transplant ..is it straight forward without mountings modifications from the half cut for RB20??
For SR20 transplant. which prop shaft is usually used?? If using SR20 prop shaft, can it be mated to a RB20 differential without cutting and welding the prop shaft??..
Money wise..
Which engine, gearbox part is cheaper to maintain...SR or RB..??
Money wise..
