8 hp up
Joeker
Walking Dead
3,580
62
Jinjang
VS kits have been tested (on dyno) and proven to work on car which have poor earthing (expecially old cars).
New modern cars which have sufficient earthing will gain very minimal if any at all.
mxsteven
208
Shah Alam
Originally posted by Yong_5290@Feb 15 2005, 02:41
8 hp up wit juz a grounding???
hmmmm 8hp up? i dont think so coz by theorically grounding just makes the current flow perfect, now are days our cars grounding is considered efficient.
for the 8hp up maybe for those rusted car or grounding problem which they already lost more than 8hp hahahaha.... so the marketing stratergy also quite wise.
maybe datsun 120y will feel the differents :lol:
stroker_kit
288
but datsun 120Y dont have ECU, so no point also....good grounding are to make sure signals from various sensors are as clean as possible, so that the ECU can work and calculate correctly... bad signals will give wrong info to ECU, thus resulting in power loss on improperly grounded cars.... yes, modern cars may have sufficient grounding, but r u sure its good enuf??
however, different car has different behavior...so the hp increase figure may varies... but at least, u can be rest assured that ur groundings are good ...
lastly, that APexi product above is not just for groundings...its a voltage stabalizer which has similar functions.... to have clean signals...cleaner than just having a good grounding....
take it this way...why not take out the O2 sensor entirely....although ur car can still run, im sure it'll produce less power than normal... this is to prove how "bad/false signals" can affect ur engine performance...
Yong_5290
3,637
49
Klang
hotmail.com
hey..u guys can check the ApexI web site....they did the dyno test on a Subaru!!!
stroker_kit
288
ya.. its not like u gain extra hp... its more like 'recover loss hp'... the hp has always been there, only that it was loss due to bad signals.... hehe
mxsteven
208
Shah Alam
hmmmm modern cars do have sufficent grounding but sometimes not all production are perfect, u know wat i mean. for engine bay must be sufficent ground. Caburator and Injection earthing theory is almost the same, Why must have sufficent ground? the alternator must be grounded properly inorder to eliminate signal ground distortion, secondly engine is ground due to spark combustion is very depend on grounding nomatter injection or carb. For injection, it need to have at lease 13v to run the injector properly, normally for ie: wira 1.6 manual, injector voltage is 2.8mv when idle and 3.8mv +-5% when reving at 3500rpm. if ur car idling at 12.5v below then ur injector will be 3.2mv due to voltage lack so ur car will consume more petrol at idling.
Some modern cars might not have enough grounding like kelisa, kenari, iswara and especially WAJA.
for kelisa maybe new model may have a better grounding coz i notice a small earthing wire from the block while the older version does not have it.
Thats my point of view.
cucuk me if im wrong hahaha :lol:
Hi all,
I don't know how to explain this but I feel that my 4 wheels like went in abit .. that makes my car look abit weird .. the other day I park my car at somewhere beside there is a Wira .. I check his wheels and mine his of course look better and fierce .. because his wheels fit perfectly .. why is this? Different absorbers & springs combination different result? I also saw some satrias same as mine. I never done before any screw setting becos my front don't come with the screw.
can...
