I just recently upgraded my BBK.
It's Brembo 6pots from used Porsche installed on to a VW Jetta.
The BBK comes with SSBH that good enough already.
The looks on it is just great but I'm not really satisfied with it.
The pedal feel isn't there. Braking is just upgraded abit from my original.
I've only got abit extra grip, feels spongy...
According to the guy that fixed my brakes he says that it's my BRAKE MASTER PUMP problem.
He says that my original master brake pump are designed to support 2 pots & it's a big jump from 2 to 6 pots. The pressure from my my pump is not enough. If I want a max full grip I've gotto upgrade the pump but road use is gonna give me the WANNA PUKE FEEL if I don't control my feet/pedal well...
What should I change for a better grip? There are afew things that I'm considering...
Step 1: Change the brake fluid.
I'm thinking of changing MOTUL 660 brake fluid as on the day that I installed I don't have much time & just top up with BOSH brake fluid. Change of brake fluid helps? I only understands that it's mainly to withstand higher temps. Doubtful about the higher pressure. Pls advice if it helps or not...
Step 2: Change the SSBH
The kit is from Porsche... SSBH should be good already. Is there any special specs that I should take note if I wanna change it? Maybe the size matters? I've got no idea at all about the SSBH. If this part would gives a good result then pls advice a good brand/spec.
Step 3: Change the Master Cylinder
Kosong... totally empty about this. Reading abit gets me to know that this is quite an important part for brakes. This is not only to hold the fluid right...?
Step 3: Change the Master Brake Pump
This is blast a hole in my pocket again... Hope the the about 2 solve my problem & I don't have to change it. What's a good brand for an European Car(Volkswagen)? Again I don't have much idea about it & don't have much time to research on it. Pls advice...
Pls advice if my selection of steps are right. Also pls let me know if what's best to skip to ensure results. In short... help me to save cost abit. I'm not asking too much from my brakes. Just a more confidence braking.
Driving style is not much of tailing, more of fast in fast out slipping.
Brake, accelerate, hard brake at times...
Like 160-180 then a brainless small lorry comes out overtaking a bus or something. Fast slow down...
