ahmedshaikhani
Hello Sir I'm planning to Turbo my 4G93 SOHC. I have Mitsubishi lancer 2006 model with me. I'm not Malaysian but I live in Malaysia as a student. My brother is doing this project in my country Pakistan. Currently in Pakistan Mitsubishi Lancer 2003 model onwards are equipped with 4G15 the new generation. Which is without distributor and is with equipped with two coil. Currently I have swapped 4G93 SOHC the new generation which is also without distributor. The engine came with automatic transmission. So I am using 4G15 manual transmission with a 4G93 fly-wheel and 4G15 manual ECU and a adjustable Fuel Pressure Regulator in order to meet the fuel requirement. I have plans to turbo this engine with forged pistons and conrods. Bore size 81.0MM and stroke 89.0MM. Which turbo do you recommend ? GT-30R ? Which standalone ECU or Piggyback do you recommend ? Injector size how much CC ? Any race bearings ? I plan to run 1.5Bar Boost. Any suggestion will be welcomed. Which brand of pistons and conrods would you guys recommend ? From which place in Kuala Lumpur or Selangor ?
