4g92p AUTO starter
oligokoko
recently i have this starter problem. very2 hard 2 start. then ive installed a relay. improvements r there but sometimes d starter wont work. thinkin bout changing it. so is there any other starter beside d original 1.6? im using AUTO gbox. ive tried d high speed wira 1.6 starter. although it fits in properly but it will produce a kraaannkkk sound after starting. so any suggestions? i want 2 have a diffrent sound when cranking d engine. any sellers here r welcome
bro.. i use wira 1.6xli, same prob.. but it's not at starter or wiring (oredy put relay etc, same as u).. try push up the socket behind ur steering cover..
otherwise just change the whole set key (but it's not particular for me to go as far as that).. decision at ur hand..
you can either look for ball-bearing starter (if you want nice sound) or check the ignition key switch at ur steering console.
