4AGE-20V Spark Plug
GT20v said:
sincere,
thats a nice plug.meaning ur afr is good..or maybe lean a little bit hehehheh.
higher heat range will make ur engine coolder.its good right??? yes if ur engine is running high deg of timing or maybe a turbo or maybe rev none stop 5-8k...
problem will occur during low,relax condition..will make ur engine coolder.NA engine need around 80-90c of water temp to burn the fuel properly.and remember ecu ign timing n fuel also diff according to temp sensor.
Thats why explain the suck low end issue from CorollaGT??
Sifoo ..isnt the thermostat suppose to keep the water temperature around 80-90 deg.Even if slow driving,the temp never goes down right.But if we talk about combustion temp,thats another story,hehe
sincere1 said:
i use denso 0.4mm ik22 (7 heat range) cool plug
after 2 months i checked
plug is in white colour (see photo attached)
think should go more cool plug
ie ik24...
zul, how your comment
http://i100.photobucket.com/albums/m37/sincere777777/plugcolour.jpg
thats mean not enough fuel. not the plug too hot.
i try on my iriway 7, go get brown color, the AFR have to keep around 12.5~13.5. so your AFR should be around 14 above.
CorollaGT said:
I have exp it. Denso Iridium IK-22 make 4AGE 20V low end power suck and bad FC. Should go for IK-20.
TQ
depend on your engine condition and mod. and depend on your driving style also.
for stock standard, or doesn't rev much, IK20 is good enough.
opsss.......salah...
combustion chamber temp
i use denso ik 20...nice pickup and a bit better in terms of fc i think..need to run in first.
how about silver top 20v.. wat spark plug shud use...
does it will affect FC ....
thanks
Write your reply...
