2-way AlarmVehicle Security
Brand : Txxxx 2-way alarm ( pls call me to ask for the brand )
Model : TN-518E new model ( same with T-521 )
Age of Item : New Item
Offer price : RM345 only
Warranty : 1 year
_______ ___ What's the Features? ___________
1. LCD screen
....It has build in LCD screen in your remote control. That's mean when somebody try to steal ur car, then ur remote will be ringing and show you the figure ( information ).
2. Auto Start
.......you can use the remote control to start up ur car engine!!!
3. Trunk Opening
........you can open the turnk bonnet by remote control. When u press the button, then the bonnet will be open automatics.
4. Anti Robbery Smartly
.......When the car is robbed on the road, you can use the remote control to make the car engine shut off automatics and can't be started up again!!
5. Shock Sensor
......This TENON alarm is come with Shock Sensor, so when the thief is breaking ur glass, then the silent will be ringing, and you also will get the information by remote control.
6. Brake Lock
......After u starting the car engine and pool down the brake paddle, the doors are locked automatically. After the engine is shut off, the door will be opened automatically.
7. Auto Relock
.......If the door isn't opened in 30 seconds after u unlock the door, the system will return to guarding state automatically in order to avoid error operation and canceling the guard.
8. Kill Starter
.......When your car alarm silent is ringing, then this TENON alarm will be help you to cut off the Starter, Ignition and Fuel Pulm. That's mean the thief can not start ur car engine, no matter he got ur car key also!!!
9. Turbo Timer
......this TENON T-520 is build in Turbo Timer. It can keep the engine continue running for further 2 minutes after you pull off the ignition key.
10. Hitting Alarm Switch
.......you can use the remote control to By-Pass the Shock Sensor. That's mean you can use the remote control buttoon to make the Shock Sensor no function.
11. Stop Function Switch
......you can use remote control to By-Pass all the alarm funciton. When you park the car in the repair place, washing place or parking place, this function will avoid false warning.
12. Warning for low voltage of car storage battery
......This kind of car alarm system will warn when the car storage battery is shortage. When car battery voltage is lower than the initialization, the main unit will send signal to remote.
____________Contact With______________
HeLix 013-2266335
HeLix 013-2266335
