air intake from cabin
subang jaya
hai everybody, what i noe for better combustion the car need cold air from air filter to create a perfect combustion,( correct me if im wrong) and can i just make a piping from air filter to my cabin to suck cold air coz im using aircond ... so dat air must be cooler...is it any dangerous?
Ur concept is correct, cold air = better combustion but i think its not worthit. First u have alot of induction noise (noise from air coming into the enjin n stuff). Then any bonus u get from cold air is used to run your aircond compressor, not to mention the xtra pipings needed to suck air from the cabin. Its a good idea but, no offence bro, rather impractical in my opinion.
i've heard of ppl running the intake thru the aircon cooling coil just to cool it down(they move the cooling coil to the engine bay n place it near the intake)..but its rather illogical cos the energy spent to cool the air down doesnt justify the extra power from cooler air. besides, the engine sucks in quite a huge amount of air esp at higher revs...will the air cool down in time before getting pumped into the engine? dont think so.
don't think thats a gud idea bro...better u just follow others by using the funnel through ur front bumper goes to ur filter....juz my 2 cents:biggrin:
hahaha... just using CO2 to cool down ur intake... in US, there got some complete kits for NA & Turbo car... hassle free... hahahaha...
Co2 gas will choke ur engine, it will replace the oxygen needed to burn fuel. I have read about their test and actually they manage to increase 3-4 hp if they manage to prevent Co2 gas from entering air intake system. but if the gas leaks to intake hp decrease is 20-30hp.
i believe the CO2 gas used to spay on intercooler. they test with nitros also and they manage to gain 50hp, just because some of the nitros get inside air intake and burn with the fuel.
is it true that cold air should be the one being sucked by the engine? I thought the engine just need some air in order to regulate the burning process of the fuel.
cold = kecut
hot = kembang
cold air = more air molecules/sq inch
hot air = less air molecules/sq inch
more air = bigger explosion
bigger explosion = more power
hence cold air = more power
yeah i have to say most practical is use a CAI hose and put on end at the air filter and the other route it to the front bumper
looks nice also
i scared rain water enter only.. coz i've felt a myvi with stock tubing, the owner cut off the pipe going to the fender so it sucks air from in the engine bay.. when i throttled abit, it sucks wayyy stronger than a vacuum cleaner! scared might suck water also.. huhu
put it facing sideways on your front bumper....thus the air or anything coming from front not going directly to your intake...still u got colder air instead of sucking air from engine bay...
someone who mention CO2....it wasn't CO2 actually...but solid CO2...which is called dry ice......just ask some ice-cream seller on motorbike....buy from them....
*mostly those was used on intercooler..where they got container (much like pipe inside a pipe) where outer container was filled with dry ice..and inner pipe where boost/induction air go through.....
