Bring down Wira weight to 900kg!!!
William_Chee82
Too all the sifu, I do need advice of hw to reduce the weight of my wira
I am currently driving a Golf GTI plus a Wira wt a 4G92 single cam (m)....
I wld like to convert my wira to be a half street n half track...my first target is to reduce the weight...
I do luv the Wira sedan alot...
1.I am looking is to replace the front bornet wt a lighter part example corbon fiber or fiber.
2. I am looking ppl tht do make the rear bornet lighter, maybe corbon fiber or fiber
3. any idea hw to take out all the seat plus the rear seat
4. any part I can safe the weight frm the wira???
Do hope all the cifu can help me by giving good pint of hw make my car lighter...forget abt all the JPJ rule.....
first step..empty your bonnet..including removing your spare tyre,tools,floor boards,carpets,plastic panel cover...
-remove seats and carpets..also replace driver seat with lightweight bucket seat....front passenger seat also remove...with a set of spanners u can simply remove the seat...just require some time and energy to do it alone....
-remove door panels,replace power window with mechanical winding type(or better fix window that can't be opened)
-use some thinner and scrapper to scrap all tar-soundproofing materials on the body...
and replace all four window with plexan clear plastic type window...
my bet...less than 900kilos of weight....
---------- Post added at 01:57 AM ---------- 6 hour anti-bump limit - Previous post was at 01:52 AM ----------
if u want to use your car for drag...then u can cut and remove so many metal from the chasis...
but if u want handling and chasis strenght..better to do double stitching welds/spotwelds to prep the chasis..and add rollcage...offcourse u will increase the weight back..but not much....
- air-cond system you still wan arr? that removes A LOT of weight oso.
btw, if your done with your light weight, can you show me the pix.. love to see it..
yep..remove all aircond assembly including compressors and its bracket,heat exchanger in front the radiator,cooling coil inside the dashboard and all the pipes including its filter-dryer...left only the blower working to keep a breeze blow when u stuck in traffic jams.... :adore:
Replace the battery with lithium-ion type. It it supposed to be the best weight reduction mod in term of cost-per-weight ratio.
Lithium-ion battery for car? How, where and price?
I add on more: replace the roof with aluminum type.
do like this confirm lightweight
http://sphotos.ak.fbcdn.net/hphotos-ak-snc1/hs017.snc1/2638_66220107079_638447079_1563543_7800843_n.jpg
tq alot fr all the sifu advice....it really help alot....no I am not planning to enter drag race....my main objective is to reduce the weight to a very max plus is still able to drive ard city....I am going to remove all the seat this weekend n also the door panel n going to replace the front bonnet wt a lighter part.....
any good advice of wht rim shd i use...planning to keep it at 15inch ... sad to say tht I still need the air con bec sometimes I will be driving it to work...:burnout:
wat about change your fuel tank to a smaller ones?/ eheheheee.. nice..
yeah, agreed, but mahal la that one.
sure looks cool tho.. :biggrin:
http://ll.speedhunters.com/u/f/eagames/NFS/speedhunters.com/Images/Jacco%20Willemsen/Car%20Features/S14%20Track%20SXOC/blk009.jpg
---------- Post added at 12:44 PM ---------- 6 hour anti-bump limit - Previous post was at 12:43 PM ----------
go for ori japaneese lightweight 15inchi rim...superb....
if on budget, taiwan makes cheap liteweight 15" oso :biggrin:
you cud oso rentung-ize yur car, but then sure illegal one.
heres summore list of shit to remove to get you started :
back seats
passenger seat
carpet
sound deadening
spare tire
jack
stereo
speakers
power steering systems
power window remove, ganti with those pulas one..
plastic panels
roof liner
bumper supports
interior door skins
dash board
air bags
replace rear windows with lexan/plastic
center plastic (arm rest, shifter area, etc)
put in a roll cage, remove seat belts get harnesses (do not get harnesses without a roll bar / cage)
CF or Fiber body panels
replace driver seat with stupidly light racing seat
replace side windows with lexan/plastic
replace windsheild with lexan/plastic
light weight battery
light weight drag racing front brakes
remove rear brakes
the actual list goes on and on ..
hi guys bumping up this old topic. I'm converting my car to full time drag machine.
Desperately need to know WHERE i can do the below:
1. Carbon fiber rear bonet and doors
2. Replace all windows with plastic/lexan
3. remove dashboard and wirings and replace it to race switch type cockpit
4. spot weld body
