does the after market short shifter improve a lot?
let me get this straight, since ive seen / experienced a "short shifter" dat is literally shorten the length of the shifter rod and not the travel of the shifter. a short shifter is supposed to shorten the length of time for u to shift gears, by shortening the throw or travel of the shifter rod. u get me? its not shortening the length of the rod, but the travel of the rod. shortening the rod means u need more force to apply the same torque required to shift the thing in a gear, and as i experienced it around last week, it wasnt helping at all. the shift isnt smooth and everything else gets in the way, because the rod now is shorter, ur elbow gets into everything ie the console, the can beverage, lol. the throw-in length to engage a gear isnt shorten at all imo, dis type of so called short shifter isnt my cuppa tea.
now, lets talk about the real deal. the proper short shifter doesnt seem short at all, they look like normal shifter jer, but the distance / travel to engage a gear is shorten. its so short dat u wud initially think u havent engage anything!!! ive experienced a good custom made and aftermarket shorties and comparing the price and quality, i prefer to perform dis modifcation at a mechanic named abang mael in cars and conversion pandan indah, top notch job
:biggrin::biggrin::biggrin: padan muka u experienced it with my car..ehehehehe...joking!
but really..if u do have the proper..the real short shifter...tell me aite..
but from my experience..short shifter+racing clutch = :proud::proud: now when i replace my clutch to normal one...:sleep::sleep: didnt feel like before..
lol, i hit every single thing on the handbrake console when shifting wei, susah giloss!!!! change to std ler, i'll do a proper set for u ler nanti, insyaAllah.. what type / brand of clutch prior to the replaced jkk unit sir?
that one was custom made if i recalled...so i dont have any idea what's the brand..
also..u always missed the first gear..hahahaha..launch from standstill in 3rd gear kannnnnn...
like my car so powerful..
dat was the first time i missed it ler, but it kept going what.. selambaaaa
if its hard to engage, then i think the one u got from n1 was the shorten shifter rod? its like they had the shifter rod cut down, was it?
don't think so. it is slightly different at the bottom mechanism when i put it beside the original proton one. don't remember how different but its different. its not really to say hard to engage but it's like very precise and really very little movement. maybe becoz i changed the black bush too coz my original one is a bit worned out.
my elbow can rest on the centre armrest/compartment and do shifting. of coz this takes some time to get used to it to be able to shift like that. the shifting throw is really very close.
hey all..
currently using a short shifter, buts its quite hard to engage the gears..
anything can be mod to make it easier?
hahaha..
the description "hard" is subjective sir, one has to experience it first hand to give proper comment. the thing dat one can advice is to check the linkages and bushes sir
oraite.. later i check again.. btw, on installation, does need to put grease anywhere?
actually quite easy to install it ,in a wira though... heheheh..a few bolts, clips..and ur done.. did mine DIY...
yup bro DIY better....my previous iswara n my current eg also i install myself....
almost bro :rofl: not sure la bro nvr check 0-100 brapa sec but it really shorten ur shifting time:biggrin:
i'm using jasma....
