yeah, also wanna know more about x4 igbt this stuff. Coz i read in microtech web, it said LT10S do come with built in ignition amplifier. Does that means we dont need x4 anymore? But i saw alot "kit" regardless frm Lt8S or Lt10S, do pari with x4
hi bros, i got a question to ask, i bought a serial cable from the local computer shop to connect my lt8s to my handset but nothing is showing up... i tot the handset was spoilt so i tested it on my bro's car and it works... is the cable not compatible? i tried to connect the cable from my bro car to my cable thn the handset but does not work..btw i did this bcoz i donno where the ecu is located so.. anyway i went up to microtech's webbie and its down... so i am wondering if any of the pros here can help me out ? thanks
dear microtech sifu's,im using lt10s and im currently having problem with my car, everytime i release throttle when im driving on the road, the car jerks and my AFR shows and ideal af. what may be the cause of the jerking ? decel ?
Can anyone explain the advantages of Microtech X4 Ignition module ? any HP gain after installed with LT10s ?
u cant connect it to a laptop just like dat witout the adaptor, pm vteckiller for more info, tq sir
---------- Post added at 12:27 PM ---------- 6 hour anti-bump limit - Previous post was at 12:25 PM ----------
what car are u driving sir? does it originally has a recirculated bov? and now uve fitted an aftermarket bov dat vents to the atmosphere? we need more info to troubleshoot for u sir, tq
---------- Post added at 12:44 PM ---------- 6 hour anti-bump limit - Previous post was at 12:27 PM ----------
here is what i got from the microtech's site : The X4 and X6 Ignition Module Boxes are used in direct fire applications. The X4 has 4 channel output (4 cyl outputs) and X6 has 6 outputs. These are used in conjunction with LT10S and LT12S ECU's. We have chosen to now run external boxes rather than internal igniters as we once did, enabling us to run more advanced hardware on the boards to cope with our new IGBT Ignition boost function which is available on LT10S and LT12S ECU's as a standard feature.
by dat, i assume they upgraded the function of the built in ignition amp in the LTs for a better unit dat built solely to control the ignition output for better performance.
as i was told previously, the X4 is similar to an MSD. it amplifies the input to the coil, and increases the spark power for better performance. a cheaper option imo
Forgot to mention. OEM ignition coil is remove after X4 installed. One thing I notice, idling is more stable when radiator temperature at 80 Celsius.
hi, i meant my lts handset.
btw u sell used ecus? mine got stolen so i need a replacement with harness.
ohh, iam sorry for missing the point sir.. sounds like a contact issue, or the hand held isnt working well
u mean used microtech? what series sir? for what engine sir?
:slug::slug:
