>>any Seremban People<< N9
SE86
299
474
1,563
i never see before leh..but i saw one car not used in senawang..but no turbo..
perodua service center seremban is going to be in a big trouble. they said my warranty is void for the disc brakes so i report what they did to my car and they said the brakes still have warranty. The HQ person who called me told me that they willing to change for me the disc and pads to new ones from another service center in KL area
jo-e34
222
69
5,028
seremban
used to be yellow now maroon.....i guess......
maybe its just a tweaked up 4agze.......
SE, you sure want to play with the husband & wife duo?? want to challenge his husband's GC8 boh, if he still have it?? I help you ask...tell him SDKFETCDVVTVVTiBSuMiVi want to challenge them...want to play 3P....
This yellow AW feels like got turbo...very fast....maybe the MK2 engine?? :hmmmm:
Guys, the City Turbo...no comment ah? anybody see before or not? :hmmmm:
khoo198
1,948
2,067
N9
ya...n dun forget the AW11 weight is 9xxkg only....:itsme:
---------- Post added at 12:28 PM ---------- 6 hour anti-bump limit - Previous post was at 12:26 PM ----------
For sale!hehehe...City Turbo:biggrin:
jo-e34
222
69
5,028
seremban
yea...below 1 tonne.....plus.....the supercharged can be turned into a turbo charged....1.7 bar no prob.....shiok shiok boosting......
yeehau86
Feb 10, 2007
2,868
2,425
SE86 already owned the Evo X, what is AW11 to him? 4th gear already enough kot :biggrin:
khoo198
1,948
2,067
N9
how abt using Lerun 7speed:biggrin::biggrin::biggrin:
TitanRev
You think I print money?
Mar 3, 2005
8,210
3,678
Khoo, now 7 speed is peanut...see this my younger brother keep bugging me to buy him this bicycle...This shop is in Senawang..Bicycle Station..heard before...lots of good stuff there even got full Carbon Fiber bicycle frame...
khoo198
1,948
2,067
N9
my childhood time is 7speed oni ma:bike::bike::bike:
TitanRev
Mar 3, 2005
8,210
3,678
Khoo, my time also the same.....but my bicycle only have 1 speed only....
khoo198
1,948
2,067
N9
BMX:biggrin::idea:
yeehau86
Feb 10, 2007
2,868
2,425
price full of 9, really 99. Buy KE for your bro better ma :biggrin:
TitanRev
Mar 3, 2005
8,210
3,678
SE & khoo, about the EGR thing..yesterday I tried to disable it...result was a lot of smoke from exhaust with strong fuel smell, engine dies off easily when trying to move in 1st gear...power also sucks...Then I suddenly thought of this...what causes this effect.
Petrol engine (SI = spark ignited) and diesel engine (CI = compression ignited) works differently.
For petrol the fuel is injected during the intake stroke then the air/fuel mixture is ignited. Even for TC car is the same working and petrol burns more easier than diesel.
Now diesel is a bit different because the engine only compress the air until it's temp reaches optimum combustion stage then diesel is injected then you got the power stroke. That's why diesel engine has glow plug instead of spark plug because glow plug is used to heat up the air going into the combustion chamber. So during cold starting the glow plug will glow longer to heat up the incoming air. Also diesel engine has higher compression ratio than petrol engines because as I mentioned above diesels is harder to burn so you need more heat.
When I take off the EGR, no exhaust gas circulates back into the intake manifold therefore the intake temp will be lower, when the lower intake air goes over the turbo it's temp will go up but after the intercooler it goes back down so when the air gets into the combustion chamber it might not be as hot as it used to be and the piston, metal parts..etc around will also soak up the heat so engine will die off easily when you apply load to it because when the diesel is injected the fuel can't be completely burn hence the fuel smell and more smoke. I have no problem when idle but the moment I give load to the engine it dies off. To diesel engine thermal efficiency is very important that's why diesel engine has the highest thermal efficiency compare to SI engine.
Just an example: with EGR
temp at intake: 40C
temp after compressor wheel: 300C
temp after IC:250C
temp of air at compression stroke: 480C +- with EGR valve opened. (Optimum temp for ignition)
Note: diesel engine compression ratio min is about 15:1 to 22:1 hence the higher temp.
without EGR
temp at intake: 40C
temp after IC:250C
temp of air at compression stroke: 330C +- without EGR valve opened. (Not optimum temp for ignition)
Above is just example of what I'm trying to say. Also with EGR on diesel the fuel that is not completely burnt can be recirculated back to be burnt again. That's why when you full throttle on diesel at you will see a lot of smoke because fuel is not completely burnt up.
1. I think the way to overcome this problem is to increase the compression ratio so that it will compensate for the loses of heat without the EGR.
2. Pre-heat the diesel before injecting it into the combustion chamber. Even the fuel is already under pressure but it's still not hot enough. I saw in Thai that they are selling diesel pre-heating device.
3. Increased the boost, but it is limited and not sure will it work because diesel's engine rev range is different from SI engines. You can take out the intercooler but the downside is you can't boost higher.
TitanRev
Mar 3, 2005
8,210
3,678
khoo, yes..
I like DK's middle finger pose....Hahaha conclusion is...bigger CC turbo wins...Hahaha
yeehau86
Feb 10, 2007
2,868
2,425
you mean DK will show middle finger when bigger CC turbo overtakes him? :rofl:
TitanRev
Mar 3, 2005
8,210
3,678
khoo, I forgot to tell you..If you can, add an OCT to you truck...because the gases from the lubricants will re-route back into the intake and IC. after a long time, it will make the inside of the IC and intake very sticky...
About the EGR, I think people remove it mostly on older engines. I will still do some more test and see...
BLANk
1,770
6,757
Sardine
www.zerotohundred.com
some add on on the EGR...
it has 2 advantages for diesel engine...as we knw,its one part of the emission control thingy to reduce nitrogen oxide(NOx) emission and this is true for diesel engine...u knw la how dirty was diesel...hehe...secondly,a small quantity of hot exhaust gas in the air charge of a cold engine helps to reduce the delay period and the incidence of cold engine diesel knock...*the end*
correct me if im wrong...pasal i newbie in the progress~~~~
A Post Every 5 Mins
The Race is on this weekend for Round 3 of the SuperGT Race series right here in Malaysia at Sepang and Honda has 5 HSV-010 GT Teams competing for the trophy.
<!--more-->The teams were introduced to the media at the Honda Super GT party as we draw ever so close to the start of the race weekend (9th and 10th June 2012).
The five HSC-010 GT teams that were presented are...
