IMO,
9.0:1 cr wiseco pistons is the better choice. As it is forged from 2618 aluminium that can withstand > 2bar of boost. Even if its made from the higher silicone 4032 aluminum still its far superior than any factory/oem.. (out of topic abit)..
Using 9.0cr means u can achieve higher HP/torq figures compared to using 8.6/8.0cr
without having to boost as high. .
As for the MLS gasket if it's up to u. But remember, the more thicker the gasket the higher the risk of detonation can occur from the increased "squish" volume.
The head gasket will lower the compression more depending on it's thickness.
But Normally i think it's easier to find or gsr the 1.5mm compared to 1.2/1.6/etc in the market. so just proceed with the 1.5mm gasket. I myself are using 1.5mm.
U don't have to worry about the piston hitting the valves, wiseco's 4g93/b18c pistons have generous valve relief pockets. Even if u use hi duration cams, ur valves would still clear the piston dome.
But i u want to use Nitrous Oxide/NOS better use lower (8.6cr) and thicker gaskets.
Only my opinion from experience..
But the piston can still ht the valves if not installed properly :hmmmm:
