clutch questions
carlmc
guys,
tried searching but couldnt find the exact answer i want..
Do i need to change my clutch pump if i upgrade my clutch to Exedy 4 puck with the semi race cover? Using standard wira pump on Mivec Gearbox..
im having problem engaging the gears...
which part should i change? the bottom pump on the gearbox or main pump?
Pump from which car should i use? evo??
thanks...
im not sure bout that bro...
but y not u call Bryan 0125206007/ 0165449556,
owner of BR Clutch for advice.
if your pump is leaking then ull hv problem sfithing/cannot shift... if not... then why replace the pump.... maybe the problem is else where...
r u using the the whole set Racing Clutch+Racing Pressure plates??
yeah, y change clutch pump if its not leaking???
do like wat bro skywalker suggest, bleed the clutch line 1st....
n also, u may wanna check if ur clutch level is too "low"??? if its too low, u may wanna adjust n make it higher...u may also wanna ensure u fully press the clutch everytime u shift...
yes bro, im using the whole set...The thing is there is no leak whatsoever...level in the resovoir still at max...
---------- Post added at 10:21 PM ---------- 6 hour anti-bump limit - Previous post was at 10:17 PM ----------
already tried bleeding the line and adjusting the clutch higher..but after few days..back to the same problem..cant shift into gear(while engine running)...when i bleed the line again...after few days same thing happen again...no leakage...:hmmmm:
wat power archived by your car? is it when the time u drive fast then cant shift in the gear? i experience on my mivec turbo since i use fullset 3 puck racing clutch,pressure plate and etc and i always go fast and furious, i think the clutch cant longer hold the power so the gear cant shift.... so i plan to switch to 4,5 or 6 puck.....
