- Joined
- Aug 27, 2004
- Messages
- 1,309
- Points
- 3,148
Guys, it turns out that the heat shield did more harm than good for me.
By using my Cobb Accessport, I could monitor the Intake Temperature.
This is my finding so far about using a DIY heat shield with my Apexi open pod air filter.
It does help to slow down the heat from building up but should there be any heat that managed to go over or past the heat shield, that heat is gonna be trapped between the heat shield and the open pod.
I also have a Cold Air Intake hose that draws fresh air from the outside of the engine bay to the open pod air filter.
On one hand it blocks (minimise) the heat from the engine to the open pod air filter, but on the other hand it also blocks the flow of air thus trapping some of the heat that managed to creep past the heat shield.
But when I removed the heat shield, the natural flow of air when the car is in motion (from the cold air intake) helps to push away the hot air away from the open pod air filter.
Conclusion
Cold air intake with heat shield: Air intake temperature rise much slowly but also drops much slowly
Cold air intake without heat shield: Air intake temperature rise faster but drops much faster when the car is in motion.
By the way, with the Cold Air Intake my intake temperature can be between 4 to 8 degree above ambient temperature.
Conclusion
Kantoi!!
