All the best to ur car dude wira3319...
bro chris & Cons..for the reason no 1. I didn't found any white smoke from behind. That means my engine still ok. is it true?? for no 2, yesterday..i bring my car for inspection and they found out that my turbo had a small leak at the outlet..is it the reason my car got this problem? and the breather..yups there are many oil left, not only in the breather..my oil cap also have to change.found out the oil coming out thru the cap whenever i rev it...erm try to solve by this week..anyway..thanks guys for the help..
lolx.. bro it sound real funny and dangerous too.. make sure ur car well check before leave garage. Chill..
halo all sifus,
my engine also makan engine oil like crazy, no leakage whatsoever when i look undercarriage.
Sometimes when idle got lotsa white smoke coming out of the exhaust. when full on throttle also got white/greyish smoke come out.
when full on throttle sometimes car jerking also.
what does this mean??
any help would be appreciated. :)
sifu,
my car putra now using straight step-up pipe, with no brand muffler. i think the sound is too loud. i'm targetting to get the sound near to stock sound, coz i've met a R34 GT-R with 400hp but the sound is just like a stock car. i've asked him what muffler he use, but he say dunno... (stingy dude maybe). So, if i use HKS silent hi-power, is it really silent?
sifu,
sifu,
if this kind happen,only got two reason,one is piston ring and piston crack already,two is turbo oil seal leak already,for check is very easy one,for reason no one is go for compressor test for your engine,two is open turbine check the oil leak from fin or not?if got is turbo oil seal,hope can help u
do i have to take off the whole turbine? or can i just take out the intake hose from the turbine and see it from there if there's any leak on the fin? does compression test also measure any piston ring or valve seal leak?
as i remember 3 months ago i did top overhaul, they sandblasted the piston surface clean it all and change to metal head gasket. so its not possible that the piston cracked if they noticed they would tell me. so the problem is maybe the turbo, ill check it myself first if i have the time and probably will do compression test too afterward. anyway since i transplanted the engine in 2006 i never serviced the turbo. so maybe its about time :)
thanks for your help chriss really appreciated it.
p/s: if u have any recommended workshop (or maybe ur shop) do tell me. cheers.
Similar threads | |
