engine oil i use M7 GT engine oil 5w40, oil filter M7 magnetic oil filter, magnetic oil sump nut. rear differential oil i use Q8 Synthetic oil, ATF i use Q8 ATF also.
most of the shops can do if u bring ur own stuffs,...otherwise u gotta go to reputable shop like in pandan indah, sunway, subang...they got wat u wan.
unless you want to do it yourself, better get the oils that you want to use then most workshops can do the change for you la. Reputable shops sometimes the oils are a little expensive, but you can scout around.
Following last year's successful MMU Drift Attack, MMU Engineering Society brings you MMU Autoshow 2007 with MMU Drift Attack 2007. Only One year apart...
