BOT (Bolt On Turbo)
ok guys thanks....
so the conclusion change the brake pads right?
any suggestion?......
not too expensive.......
if bandid metal king......what model?....
change to mitsubishi twin port braking system + bendix titanium pad .... result perfect...
Just wondering, what management most of u guys use? Still torn between a standalone or a emanage blue or interceptor.
Not so sure if a standalone is worth it for a BOT.
Any suggestion ah guys
E-manage or interceptor, SAFC or standalone, Rechip or whatever.... All you need is something to alter your Air fuel mapping according to your set up. Whatever brand, whatever method, they exist for a reason and they are priced for a reason...
The air fuel management device that you should be using very much depended on what your set up is and what kind of output you are logically targetting...
Like what VSB is saying...
How many hp are you aiming for ??
Most turboed car are using standalone....
However, I would like to correct your statement... MOST big horsiesTurbocharged cars that are built for race using standalones. That is when sequential ignition and injection, launch controller, antilag, and other facilities are required in result better engine output. And these cannot be done by most piggybacks.
And, most BOT's car are actually using pggybacks like emanage, unichips and safc... However, there are only a few BOTers using standalones...
TO damndamn:
Worth it or not...?
If you really understand the capability of a standalones, you would say yes without a second thought.
If you really know how much horses your BOT can produce, you would say yes even if you have to pay for the price of a halfcut.
Agree with speed2horizon about comment to most turboed car using standalone..
there most bot car or turboed car is using piggyback type, not much BOTers are using standalone..
most ppl using standalone are in huge mod huge hp which beyond capable of stock ecu, for example 2000cc engine change 1200cc injector how to tune by using safc or emanage and how to idiling? which this one of the problem..
Comparing to similiar builds and makes, i would say im looking at somewhere between 170-200 whp. That is in the long run, but for now, im just looking at around 0.8bar (mayb 160-170?)
Emanage would not support >0.6 bar as slight knocking will occur cause by lack of ignition control. So now the choice would be between Interceptor, E6X or Sprint 500.
My choice goes to Sprint 500 due to the fact that is has sequential injection.
But from what i was told, if E6X is used, the aircond etc will be disabled?
Emanage would not support >0.6 ?
My friend caldina using emanage boost 1 bar with emanage blue without any problem....:rolleyes:
---------- Post added at 04:41 PM ---------- 6 hour anti-bump limit - Previous post was at 04:38 PM ----------
Yaya..agree !! :D
But last time I join jsoc.. My fren silvia S15 , evo , even 350z and more etc...also using standalone ...
actually depend on pocket money ~~ :biggrin:
guys bought already bendix......still same effect but after a certain times la.......i think need to buy disc rotor and caliper at chop shop la....ei gsr ck can arrr?.....
normally how much?....
must change everything ka...like servo?...pump?.....
Another thing anybody using haltech interceptor before install in gen2 or campro engine?..
my engine now leaking a bit.....need to check it tomorrow,....
izzit good to used double gasket or used only single gasket?
coz im using double right now.......
if i bukak and then pasang inly 1 gasket need to tune back ka?
Eh yellowstone, does it look like any of our cars here are diesel powered ar? GO GET A LIFE and sell your diesel stuff in other places lah, nothing better to do go sell your stuff here.
Plus your in CHINA for God's sake. This is MALAYSIA.
Learn how to market your rubbish lah, and sell it on the right forum, please -.-"
hi bros
wanna ask u guys what kinda engine oil are u guys using?
im currently on semi syn 10w40...the prob is ....everytime when i travel approx 1000km....the oil level will drop to the min level....im guessing is it too thin for my engine considering the amount of heat produced...4g93p bolt on here....and im only using 1 pair of cooling fan instead of 2....
Yaya..agree !! :D
My friends' supras and skylines using emanage blue... Good enough as in daily driven. Of course standalones have more capabilities and features.
E-manage is teh one with ignition control... Pls do some research.
GSR CK is not much differs from your gen 2 disc brakes, U can look for EVO 4 caliper and disc. Twin pot.
U can, it'd be better if the braking system comes in a set of course. But it's also ok without the servo.
Nope. double gasket is not recommended. U can either look for thicker single gasket that have the same thickness with ur current double gasket or u go for retune.
hi bros
Don;t understand. 1 pair of cooling fan..? 1 pair = 2 ma...
10w40 is fine turbocharged. No problem.
Have you removed ur water line on ur turbo..? Any white smoke..? Engine oil burnt smell on ur exhaust?
I heard Lucas is quite good... BUt Good oil comes with a price..
Taiko...wanna ask you .. After install turbo.. need to change engine oil ??
I next 2 week will start install the turbo...feel nervous ......:biggrin:
sry i mean im just using 1 fan now...cz the banana occupied the space for me to locate the 2nd fan
no white smoke...but i do smell oil burnt smell frm the exh....
Terribly sorry for the misunderstand.
What i ment was, with emanage, additional/optional harnesses would need to be purchased and with those included, my main question, am i better off with Interceptor?
Not necessary. But I did because of 2 reasons.
1) It's already running for 7000 Km.
2) I want new oil to enter my turbo.
Use the mitsubishi external fan lo. Cable tie it.
The smell could come from ur piston rings/valve seals/turbo bearings.
The harness can be DIY. Most tuners DIY themself.
The price justify it, didn;t it..?
mitsubishi external fan....may i know from which model?sry noob asking ques...haha
oh yea..now im experiencing so prob...every time when i start my car and drive off....it alwiz jerks as i try to accelerate....happen approx when the boost needle starts to climb from 0 onwards...once it passes approx 0.2-0.3 mark...its not jerky anymore....
2nd ques...any reliable workshop to recommend for 4g93 bot?cz my mech decided to close down his shop =(
1) any lancer 4G9X or 4G6X. Normally ppl just buy EVO's fan. But it depends on the distance between ur condensor and ur ic piping/intercooler if it's sufficient for the fan.
2) Should be incorrect AFR at that RPM range. Does it happen previously..? What injectors are u using..? Have u alter ur wiring to use Low impendence injectors if u are using 390cc?
3)I can recommend u to my mechanics. But this fella do things u cannot ask too much things... If he's in nice mood, he do things nicely. If mood not nice, he dowan do... like that one.. So, U have to trust him if u send him the car. My BOT 1.6 is done here.
ooohh...it just happened recently...after monitoring for a day...i found that it happen most of the time once the boost kicked in...using 390cc injectors and have not altered my wiring before....
where is ur mech place?
can always buy perdana v6 fan..
is very powerful and lasting
Well, have you heard of Low impendence injectors...? GSR 390cc injectors are low impendence injectors... If used in a high impendence wiring set up, can cause harm to the ecu... But i'm not too sure if the ecu have been damage by the wiring and injector. cause worse case scenario, can cause ECU to burn. If wanna use on a normal set up, have to add resistor pack onto the wiring.
My mechanic is at Sek 27 shah alam.
Problem is the space, not the specs. Fan relocation cam be a good solution.
