Jun 304' VS rpw 306' VS tomei 316' ????
Boy_HS
sabah
hellooowww to all zth members.... i need suggestion bout the high camshaft for 4g93 n/a especially from otai2... which of this camshaft give more increase ??? Jun 304' or rpw 306' or tomei 316' ???? high degree not mean can gain high power right ???? :itsme:
cams alone will not determine the output. tuning + lots of other mods/setup plays a vital role as well. i call it a black art of tuning. other factors also play a part i.e. drag/cct/street use
just my 2 cents
just my 2 cents
Tumpang tumpang....
Man,,,
The adaptor flange- B series--> Mivec, the machine shop guy wants to charge me rm450....
damn expensive... (ISO9002 compliances Company) need to make drawinglah, EDM lah...
Anyway crazy price compared to JB....
So how you wan to proceed?..
I make manual drawing (trace the sample on paper) and send to you can?
Then you find your local machine shop guy to make.... Can? Want?..
You will need aluminium plate... 17 inches x 4 inches, thickness= 1.2-1.3cm..
Let me know okay...
all these camshaft are good but bare in mind that u need to make sure that your engine is high in compression (10/11.1 at least) to use this "race only" camshaft (3++). if not u cannot fully utilize this camshaft power.
p/s: rpw doesn't offer 306 degree camshaft but they offer 316 degree (stage 5).
high degree and also valve lift is very important....
like Bro joemirage said...make sure your engine has enough compression...
and like bro manofwar said....it all comes down to tuning...make sure you at least have a piggyback and ported head ...and get stiffer valve springs...
choosing the right set of cams really depends on your engine mods/stage and target...hard to just point which cam will be the best for you....
thanxxx for all.... now i have my own choice oledy... intake i will use tomei 316 and exhaust i will use jun 304.... but my foreman said tomei 316 must be lay a little bit coz takut lambat tutup... now im using 2.1 stroker kit from aus, unichip ecu management, skunk2 intake for 4g93, n final decision is using tomei n jun camshaft.. thanxx again for all zth members for suggestions... :smokin:
wow monster on the road!!!!!!
hmmm.. different brands of camshaft? meaning u have to buy jun and tomei? a lot of money involve here.
WOW!! how much for the skunk 2 intake and 2.1 stroker kit??
stroker 2.1 around 8k smthing... intake under 1k only.... but need to be 'cool' cozz the stroker take a long time to come here... hehehe... im waiting until 1 month and then arrived... hihihi..
---------- Post added at 10:33 PM ---------- 6 hour anti-bump limit - Previous post was at 10:27 PM ----------
nop... i have my friend using gsr turbo and need the tomei camshaft for exhaust n jun camshaft for intake... so, i take tomei intake camshaft n jun exhaust camshaft.... hhiihihi.... :smokin:
---------- Post added at 10:37 PM ---------- 6 hour anti-bump limit - Previous post was at 10:33 PM ----------
i hope so ma friend... :driver:
wow...thats really $$$$$. mind sharing some info on the stroker kits...crankshaft & conrods.
keep us update with ur monster mods
if i not mistake, conrod of the stroker kit short than the original... piston size 83mm... must use custom liner for safety... crankshaft, conrod n piston very2 lighten weight... i dunno it can go or not... im waiting for my camshaft now.... if my engine mods completed, i will show u my engine.... the important thing, i really2 trust the unichip management....
cool man... should be kinda powerful oledi... you plan to use it in street or track? Your mech order all these?? or you did it through ebay?
jz wanna ask...betwen jun 272deg 10.8 lift n tomei 272 11.1 lift if im nt mistake, whch 1 better in overall perfrmnce??
tomei will be better in terms of performance since the lift is higher.
im use it 4 drag race 0-400m... hihihii.... before this im using mivec 82mm piston only n used 272 RPW camshaft.... best time i have is 13.4xxsec in sandakan drag race... now im trying to get a better time that i have.... hihihi... just wanna try da power of my machine for funNnn.... all of my part is personal order from my foreman.... :wavey:
---------- Post added at 08:19 PM ---------- 6 hour anti-bump limit - Previous post was at 08:11 PM ----------
me too think the tomei camshaft is better.... but remember, its depend on your tuner to set the cam... :driver:
hey guyz, i have a fully stock 4g93p NA engine and i'm considering tomei's cams as well..i need some suggestion as i'm really clueless on this..i'm not using it for cct, it's more for the streets. therefore, i think that 316 will be too much? i know i will need a piggyback and adjustable cam pulley but other than that i'm clueless once again, lolz! so pls advise!, plus i'm thinking of installing nos after the cams have been installed.
advise and comments please! thx! :D
just my 2 cents bro...if STREET is what ur after...then max of 272 will just do it. thats why mild or street spec cams comes in 262, 264 & 268 (but marketwise its rare to find those profiles). however with proper setting and tuning a 272 is the most u wanna go with.
properly configured 4g93p can churn out approx 150hp on wheel which is good in daily driving as well as fuel consumption.
ooo~~ okayokay..coz my mech is telling me to take the tomei 280 with tomei campulleys..hmm..which the cam pulleys are killing as well in terms of pricing..lol..izzit necessary to get tomei pulleys or any other brand's pulley such as arospeed? or if changing the pulleys are even necessary? thx for your advise manofwar! :D
not sure tomei has cam pulleys for 92/93's. although hks has it nowdays. arospeed is nice and value for money but i believe there are also custom & moded adjustable pulleys to suit ur budget.
