hi dear sifus that owns and drive a kancil here.... can you explain wats the difference between L2 and L5? the engine capacity, hp etc? thx!
this is the different between L2,L2s,L5
L200(EF-CL) - 659cc 6v sohc 40ps/6.5Krpm 5.3kg-m/3.5Krpm NA
L210s,210v(EF-HL) - 659cc 12v sohc 50ps/7.5Krpm 5.3kg-m/4.5Krpm 4WD turbo
L200(EF-XL) - 659cc 6v sohc 61ps/7Krpm 8.6kg-m/4.5Krpm turbo (carb)
L200(EF-KL) - 659cc 6v sohc 42ps/6Krpm 5.4kg-m/4Krpm NA
L200(EF-FL) - 659cc 6v sohc 40ps/6.3Krpm 5.3kg-m/3.5Krpm NA
L200,200s(EF-JL) - 659cc 12v sohc 64ps/7.5Krpm 9.4kg-m/4Krpm turbo
L500s(EF-CL) - 659cc 6v sohc 40ps/6.5Krpm 5.3kg-m/3.5Krpm NA
L500s(EF-KL) - 659cc 6v sohc 42ps/6Krpm 5.4kg-m/4Krpm NA
L500s(EF-FL) - 659cc 6v sohc 40ps/6.3Krpm 5.3kg-m/3.5Krpm NA
L500s(EF-JL) - 659cc 12v sohc 64ps/7.5Krpm 9.4kg-m/4Krpm turbo
L500s(EF-GL) - 659cc 12v dohc 52ps/7.2Krpm 5.8kg-m/4Krpm NA
L510s/510v(EF-ZL) - 659cc 12v dohc 55ps/7.5Krpm 6.2kg-m/4Krpm 4WD NA
L500s(EF-RL) - 659cc 12v dohc 64ps/6.8Krpm 10.7kg-m/4Krpm turbo
L502s(JB-EL) - 659cc 16v dohc 58ps/7.6Krpm 5.8kg-m/5.6Krpm turbo
L502s(JB-JL) - 659cc 16v dohc 64ps/7.5Krpm 10.2kg-m/4Krpm turbo
L512s(JB-JL) - 659cc 16v dohc 64ps/7.5Krpm 10.2kg-m/4Krpm 4WD turbo
thanks bro and btw do u mean tat 16V means 4valve per cylinder for 4 cylinder engines?
for certain L5, it uses 4 cylinder engine... you can identify it from the list based on its code... it starts with JB, JB-EL for NA and JB-JL for turbo... Daihatsu Move L6 also uses dis engine...
FYI, for Move L9 series it uses JB-DET with a redesigned head... some says more efficient but still the same block as L5/L6 JB series
icic...thanks for the info...btw i think i edited my post while u were replying so u miss out some questions i asked....i was asking whether there are more L2s or L5s converted on the road? which is better??
thx for the very comprehensive summary of pros and cons for L2 and L5, anyway congrats on your L5 conversion. Previously were you using L2 convert? btw how much does the half cut for L2 and L5 cost? :)
oh thx for add info but klang sounds far for me, haha ...i am located in jb. Anyway i am aware that kancil comes in many different models, how do we actually classify them and what are their specs for eg: the 660cc and 850cc in terms of their hp and stock 0-100 timing(or maybe stock engine cant really hit 100?). Also how much does a kancil modified/unmodified cost?
I apologise for the huge influx of questions but i think it'd be easier if i ask most of my questions in a single post, so it'd be easier for you to reply... :D
ohh...any idea how much those cost?
what cost do you referring from?
oh i mean the cost for buying a kancil 660cc and 850cc stock and modified....
haha... i think you should search the "Cars for Sale" threads
, thxSifu giving advice man!!ha3..
Actually the most powerful stock mira are L500s(EF-RL) - 659cc 12v dohc 64ps/6.8Krpm 10.7kg-m/4Krpm turbo (look carefully.. its 12v onli.. 3 piston..he3)
if u are using 850 twin cam kancil engine.. u can just rojak it inside.. to power out will be beyond ur expectation...
me using this engine for 4 years already... stock auto power are much more better than manual l2s turbo...spare parts.. tons of it...he3 look on the torque not the bhp and cc anymore..
u will knoe once u have it..
can anyone give a hint...thanks...
