Rechip / Emanage
Awesome possum! Kendrick, when u joining us open track day?
Agrees with you. What is good to increase rev IF the engine did not improve it's engine respond ? (better torque in the low and mid).
Simple example, if you increase to 9000rpm and produce 140whp with the B16A or B16B (still not a 2000cc yet), no matter how your 6800rpm will still producing about 120whp (assuming), so bassically your engine respond dint increase, your 0-100kmh still the same, just that you can rev higher.
Unless you driving on a track and high revving all the time, if another car has lower whp compare to your car (after upgraded to 9000rpm) yet has better engine respond and improve torque, dont be surprise you will kena smoked kau-kau before you can rev until 9000rpm.
It would be better if you do some internal mod first and improve the torque, improve the engine respond and get Emanage Blue to fully utilize the mod you have done. Then learn to use all the power n improving your driving skills.
By then, only upgrade to 9000rpm after you understand what kind of power n potential your engine produce n harness them with your skills.....That wont be too late.
In fact in the process, you learn more about your car n improved your skills.
I donot drives or own a honda, but what I can share with you previously my SR20 n/a produces 158nm/wtq (wheel torque) at 48000rpm, after I port n polish with highcam and with the help of Emanage Blue, the early torque was 160nm/wtq at 3200rpm.....and peak torque was 172nm/wtq at 5500rpm.
Can u see the different between stock wheel torque 158nm/wtq at 4800rpm, and after Emanage Tuning and internal mod it become 160nm/wtq at 3200rpm.....
3200rpm and 4800rpm is a HUGE different. And with this alone, I have already smoke SR20VE (VVL Engine) in a tight short course, coz the SR20VE VVL canot even perform (unless using Emanage to activate the VVL to open as early as 4000rpm (1st stage) and 5500rpm (2nd stage).
Just remember, if your engine internal wasnt even upgrade, rechip n upgrade to 9000rpm, will not improve your engine respond, just a wider band to rev, it could help you 0-100kmh to perform better since 1st n 2nd gear can high rev, BUT thats all.....nothing much you can do.
my1cent
wow. a good explanation. yea...what i gathered also the same. rechip ... yes u can increase ur rev limit and so. but my intention is to touch the internals in near future. yet now perhaps ill opt for the emanage for stock tuning purpose ie: mods of i/e/h.
came to my AFR on my B16B was relatively high... vtec engage at >6500< and air fuel were up to 14 when the vtec its about to engage..thats why im just producing with only 144 on wheels for my b16b.strange eh? note that was the time i only mod my piping to 2.3" with back muffler and simota intake. still venturing for a header (4-2-1) then will go for tuning. 14 on AFR dangerous line?
Just for light mods and newbie, I'd recommend the emanage for your purpose. Easy install and tuning. You can play around with many things and revert back to your 'good' settings at any time. The tuning files can be saved and reload at will.
For heavy mods and racing, then opt for standalone.
Same same laa.hehe...:rofl:
hAi all,
Sorry to intrupt..
Question, as ioki using OBD2, is it can get cheaper price for re-chip? I talk only OBD1, which more explored, easy to get chip (no branded). Correct me if i'm wrong..
And some Hondakian say, OBD1 much better than OBD2....
14 is a bit too lean ....... particularly when v-tec's activated.
dont kaboom the engine :rofl:
wokeys noted.perhaps ill be going for emanage then....for the time being im sourcing an aftermarket 4-2-1 header.... any out there?
Hehe,
It is not surprisingly that on papers B16A is about 170hp, but actual dyno will yield 120+- whp. Many of my friends owns B16A also tells me the same thing, after doing some mod, getting 144whp on your car is very impressive already.
I will be frank with you, if you really going to make a VTEC really good, just bolt on a turbo, fine tune it with the right boost with emanage, is good enough.
Originately, VTEC is built for fuel saving, and monsterous pulls when VTEC opens. But if u really understanding the vtec, it has draws back too, especially on hillclimb like genting, where only 2nd gear shines most the time. If you have a turbo, u can use 3rd gear to climb utilizing the turbo boosted- torque, if u using vtec to climb, engine will KO very soon coz overheat.
Just consider, research, save up n spend on the right things, or else will regret....I seen alot ppl regretted coz modded wrongly, hehe
mayb the sifu's who tune ur friends vtec not so pro enough gua.........:smokin::smokin:
Hehe,
YEA i get what u mean...i nvr intend to go more togh......just want to get the most of a NA engine./...most of us know that a NA doesnt produce good figure on the paper....for a normal i/e/h i opt to expect something. looking on the paper the B16B was quoted with 185BHP well perhaps on wheel it should be -22% from the original figure ? correct me if im wrong/. to minus another 2-3% for the age & usage of the engine would make it around -25% 185bhp - 25% = 138++ WHP ...i dunno wheter is it correct. (note that calculation is base on stock and on the papers) :-) please guide.
Yea Vtec with BOT does have a good power figure with proper tuning.... but TURBO.... like inserting silicon onto a gurlys booby..hahahaha...neway sr18autech i do agree on ur statement. :-)...thanx for the guide too :wavey:
