why B16A brake not efficiency ?
performance..??:confused:
hehehe... lighter caliper can makes ur car accelerate more faster, claim more G's as for sure...
if u mean the stopping power, as for sure, its better than ori EK4 or slightly better than EK9...
pad do the most important part to stop ur car, no matter how many pots u got... so, get a better pad for ur stock calipers or ur new wilwood. as i know, Endless or PMU or some other Jap pad do not carry the wilwood sizes...:smokin:
u mean wilwood brake set is lighter than standard/EK4/EK9 brake set?
am asking bout performance bcoz i did read somewhere saying that those aftermarket brake set such a grippen are very bad in grip and the set is heavy too,so i tot wilwood more less the same,
now day im seldom riding my Honda,just pagi2 panas enjin saja,
wont dare till this braking system settle
ok, easy numbers: EK9 calipers= 5.xx-6kg per pc for front, while Wilwood only 2.xx-3kg.
EK9 front disc bout 7kg while Wilwood r 5.xxkg...
so, wat in ur mind now..?
p/s: can't give u the actual numbers coz the list not in hand. thanks.
emm..look lighter than the stock ek9,
any comment on the brake power?
the bite will be more less like ek9 or...:hmmmm:
I use a complete set of EK4 DOHC Vtec disc+calipper+pump.... later changed to DC2 pump... Works fine though...
what diffrent does it make?
EG9 BIG VTEC, EK4 also BIG VTEC,
so braking system should be the same..
eemm..i wonder how what are the diffrent..
is it got diffrent disc size?caliper?
yalor... just the raer difren only...
no bite, just change the pad ma...
yalor, just change the pad,
jin,how gud if we change the braided hose??
any gud brand for this hose?
saw someone selling PRO RS, ok or not?:hmmmm:
Since brake hose no need to change always, so i will suggest this brand, http://cart.zhapalang.com.my/product_info.php?products_id=128(UK product) brake hoses, originally developed for Motor Racing, feature stainless steel braided hose, which doesn't expand like rubber. The result? Better, more responsive braking and reduced stopping distances. Besides its also provide a lifetime warranty, this show how they confidence in their products.
http://www.goodridge.co.uk/images/kitpic.gif
will be better pedal feel such more firmly when press...
most of Honda guys using Mugen, APP & Endless... & some using PMU....
Pro RS... ok 1, but it witout a layer of protection rubber outside the steel braided hose...
