what is the BEST BOOST CONTROLLER ?
hahahahah bai itu barang boost con ke picagari? :rofl:satu kali henjut 1.9 bar pecah gua rasa itu barang:proud:
sial , lolx u put rajinikanths picture as avatar, i was laughing till i drop on the floor
boost controller hallmann one of the best , from US
i am using blitz sbc i-colour.so far the dual boost solenoid is good at holding my preset target boost and didnt screw up.good thing i like about it is , there are optional sensors you can purchase so it can read things like pressure and temp as well.there is graph readings from the display itself and its pretty precise and accurate.4 different boost map settings you can set and change on the fly.warnings and boost limitations that keep you within the safe limit.best of all, its colour lcd screen.cool aye? LOL
i've use the hks evc6 before this and the stepping motor solenoid screwed up just within 6mths of usage.replacing that part alone is expensive so i skipped it and bought a new sbc icolour instead.
buy direct from MUTIARA MOTORS but it's pretty inconvenience cos u have to bank in payment to them unless u r staying at johor, then u can directly go to their shop and buy..
thats real cheap dude.is it we also can get this price ar..? hehe.... my plc here sell 1.2k best price already
i think greddy profec B is better..
trbosmart dual stage pon lg ok..
blh scramble boost bl gear 3..
hihihi..
for me the best is TURBOSMART e-boost(using it for about 5 years,no problem at all):smokin:
hi all,
how about the works-engineering manual boost controller? anyone try it before?:hmmmm:
hi all,
not good enuff la..
if u wanna buy that then beter buy turbosmart boost tee...cheap and very very good...
http://www.turbosmart.com.au
not good enuff la..
wow... turbosmart !!! very impressive ne.
Bro, I just add on turbo kit for my small cc 4G13p oni... but u all is with monster car leh.
TD04L , injector still stock..... wlabro fuel pump installed edi. When boost around 0.2~0.3 bar the check engine indicator "blink blink" wow...:confused:
Might need go for bigger cc injector & FPR...? But some giving idea such as add a boost controller to set the boost for 0.25 bar to solve the problem...
guy's... any suggestion not?:itsme:
Thanks ....:driver:
Thanks ....:driver:
sure la check light come out...
the original 4g13p runs on map sensor...when the map detects boost the check light will come on..thats totally normal...
if u have a piggy bag ecu or something all u do it clam the voltage of the map sensor and the right voltage b4 boost then u have solved this problem d...
no no no probs...piece of cake! :biggrin:
TQ,... bro, for the advise.
soon get e-manage to fine tune it.:biggrin:
turbo smart any boost controller olso nice one,very respone and stable,sure can let u can got boost,not only display the bar or psi digital that number like the apexi avcr or hks evc and gready electronic boost controller,at the same time u boost 2 bar electronic boost controller(display number),but u try to see your boost meter all hand set,will see only got 1.4 bar~,turbo smart boost controller never got that problem,just my 2 cent...:biggrin:
