WHy delete the post... cover line?
haha cover cover
turn up ur boost controller la keke..n u definitely need at least 8 injectors bro,4 of 1850 not enough,ur running e85,at least 8 of 1600cc injectors then u'll see 1000HP marks kekekeke
Not 8 for 1000hp.U have to put 12pc for serius and safe line.Direct fire for 8pc and stage for 4pc again.
use 4pcs 2200cc injectors okay d la..Need to clean the fuel filter first.. it should be only at 90% duty cycle for that kind of power.
cheap and ready stock...rm2300 only for 4pieces.... :)
can take tomorrow and tune again tomorrow nite...
very tempting... can it idle at 0.61ms?
Is it the same as magnus 2200cc injector? If Moran injector i think it start opening at 1.5ms... how to idle? at 3000rpm?
Magnus 2200cc Methanol Fuel Injectors
http://www.magnusmotorsports.com/images/2200ccinjectors_thumb.jpg
For those of you who want to run methanol, and a lot of it, these fuel injectors are for you. With a flow rating of 2200cc, duty cycle wont be an issue.These injectors can be used in combination with our Magnus Methanol Fuel Rails.
jo1 did fine la shah!I got a new one in australia siemens deka 2350cc and 2500cc custom for XR-6 ford 1+++whp just fine tune using 6pc injectors and E85.Boost 47psi boost.price only RM3500
Bump: Jo1 you are wrong AFR for stoichmetric.You should put 10.5AFR for idle and for methanol is 7.2AFR.And for boost you have to think about that.
well done to Jo1 with the S4 turbo... smooth run..
so who actually tuned it ? :hmmmm:
i think he personally tune his car.....congrats jo1 !!!
There has been some problem with the car with fuel delivery system during the dyno on saturday afternoon. The pumnp be the culprit making the injector working at max duty cycle with inconsistent afr during e85 tunning.
Borrow Jo's(vteckiller) fuel pump, clean the injector and change the fuel to unleaded race gasoline all done at Millennium. Back on the dyno just after 6.00pm with Jo(vteckiller) doing the tuning and it finish at around 7.00pm with a decent power. The car respond nicely to the tunning, if we got more time maybe can squeeze a few more from her. Off to Sepang after that hoping all the hard work materialize.
Then good thing happen, we been able to get the 1st. place for cat. B.
Thank all for the support.
Zam and crew from Carwox :proud:
Ainol the hell raider...
Joshua and crew from millennium
Mail from Penang for the gearbox.
Thank you all.
Just to clear up on the misconception about AFR for my tuning.
Lambda 1 is stoichmetric for every fuel which is equal to 14.7 for gasoline and 9.75 for E85. I'm tuning the car with gasoline AFR, so if at 11.0 it already around 7-8 for E85 and around 0.7 lambda. It maybe off a little bit but it not all about target AFR a lot more thing need to consider when tuning.
But don't worry about the tuning, I am still in the learning process... practice make perfect. Thanks a lot for pointing it out.
Anyway, Jo really done it with a limited time. Kudos for vteckiller.
What is the Timing for 1st place jo![]()
JO1 is a GURU's know....hahahahhaa![]()
Not guru la boss... still learning.
Lesson learn during this drag: leave it to pro... less time with no headache.
