Feel Like Top-Overhaul
clementchong_86
D'Carbo Sales
Is your vehicle...
...More than 30k on mileage?
...Less power? ...Feels heavy?
...No power in climbing hills?
...engine not smooth and not stable while idle?
...Consume heavy fuels than normal?
...Having problem to switch on especially in the morning?
D'carbo is the solution and its already proven in laboratory and tracks/road!
D'carbo is suitable for all vehicles (new/old, petrol/diesel, carburetor/fuel injectors) - turbo or normal cars, vans, lorries, buses, trucks, MPV, motorboats, etc. Works for both new and olds cars, which has mileage more than 30,000km.
D'carbo has two certificates!
1. SIRIM QAS INTERNATIONAL
REF NUM: 2006KL0920
2. TESTED BY SPEEDWORKS LABORATORY
Characeristics of product
1. Clean up carbon in the combustion chamber, valves, spark plugs, piston, cylinders and intake manifold.
2. Like having top overhaul. But top overhaul may cost you hundreds or thousands of dollars, depends on type of cars. This D'Carbo cleans your engine parts, you may not need top overhaul anymore.
3. Old engines felt like new. Feel your engine lighter and faster.
4. To reduce fuel consumption. Less carbon, lighter engine means less fuel consumption
5. Boost performance and horsepower for higher speed and acceleration whether on flat horizontal or slope level.
6. Smoother running engine by promoting a more complete combustion (reduce noise and vibration).
7. Easy and improve engine startup especially in the morning.
8. Extends engine life and cleans your engine by cleaning existing Carbon/Varnish Deposits – clean up all the carbon depositions that has been built up and stick inside the fuel hose, fuel injectors (or carburetor), cylinders, valves and engine that has been built-up since new. A correct combustion avoids these troubles and also allows a considerable savings, increasing the engine’s performances. The cleanup may take several kilometers of driving, depends on the type, year and condition of engine.
9. Shield, extend and lengthen the life span of silencers, valves, cylinders, converters and spark plugs – save your money on the servicing costs!
10. Diminish dangerous, hurtful and polluted exhaust emissions (black haze, smock and poisonous gas emission) – Almost 25% reduction in hydrocarbons (HC), around 60% decrease in carbon monoxide (CO) and about 8% improvement in carbon dioxide (CO2). Let us make our vehicles world friendly and good for flora and fauna.
11. Reduce engine temperature and sound.
12. Cleaning process in less than 15 minutes with no tools needed!
13. Will not affect vehicle warranty - no cutting, no modification to the engine. There are SIRIM Laboratory proven certificates.
How does it works?
All vehicles after running for several kilometers, will experience carbon build up in the fuel line, combustion chamber, valves, piston, cylinders, etc. Now, introducing D’Carbo, a technology from German, acting as a very effective carbon cleaner. Cleaning the carbon can help to optimise the performance of an engine so that the engine will be like new condition. This latest technology is called Preventive Maintenance Technology (PMT).Fuel combustion is NEVER complete for all vehicles. That’s why we can smell petrol and see black smoke from our exhaust pipes. But after cleaning the carbon using D’Carbo, you will find some water coming out from the engine, which means the combustion is now complete. There some chemical formula that shows if H2O (water) is produced, the combustion is complete.
Try One TODAY. You will feel the different man... It's WORKS!!! I TRY IT BEFORE on my Perdana.
Compared between a Carburetor engine and a EFI engine.
This D'carbo works better on the EFI engine right?
i can post it to you bro. you want how many botol? thanks...
Bump: hi. i can post to you bro.
you want how many botol bro? thanks...
