biz-da-tech
520
but pipercam of mine have sound wor. but not very loud. but now no more sound. after that use 5w40w engine oil....
btw all BRo. got a bit question.
may i know what else are different between 4g13p and 4g15p engine?
block and piston are different to 4g13p. and wat else? intake manifold and others???
currently i knew that 4g13p engine and 4g15p if change block u can get between 5 to 8HP different and then torque are higher quite alot den 4g13p.
Bump: but pipercam of mine have sound wor. but not very loud. but now no more sound. after that use 5w40w engine oil....
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
only the piston and block is different...
4g15 piston has larger bore size compare to 4g13
4g15 block has thicker cylinder wall compare to 4g13
otherwise, everything is the same
biz-da-tech
520
really?
only different like that only?
is plenty that upgrade to 4g15p piston den >.< LOL
and i heard powerzone extractor are good >.< again. gain alot den those cheap stuff .
cuz im using cheap extractor (with stright pipe exhaust) and arospeed cam pulley and got other people mod this two also but on powerzone brand extractor (with GTI ori muffle) and gain better hp. who really see this happen?
btw also that ahmmm. the piping size are same too?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
really?
powerzone extractor good... but how far difference compare to local cheap aftermarket ones i dont know... at least powerzone has dyno graph to prove to u dat their extractor DOES improve horsepower... u paying more for the assurance... as for el-cheapo extractors, depends on ur luck... haha..
alternative choice for good extractor are from hotbits and wira se original extractor...
not sure what piping size for powerzone extractor though... wait unker donjuandemarco reply...
biz-da-tech
520
yes i wanna know piping size of the 1.5 what inch u using skywalker? :) but how much powerzone extractor ? how about the brandless stainless steel quality??
Bump: yes i wanna know piping size of the 1.5 what inch u using skywalker? :) but how much powerzone extractor ? how about the brandless stainless steel quality??
ettm_14
605
81
hmmm...was wondering if I change timing belt, will it affect my settings for my cam pulley?
langsuyrx
331
43
3,028
Kay L
facebook.com
i have try pipercam, the brop..brop..brop sound is not that noticeable la..wrong setting, can assure u will lost power...
Bump: i have try pipercam, the brop..brop..brop sound is not that noticeable la..wrong setting, can assure u will lost power...
DonJuanDeMarco
134
powerzone extractor RM450.00 including installation..
Bump: powerzone extractor RM450.00 including installation..
ettm_14
605
81
don: if 4g15 auto, what do you reckon?
Bump: don: if 4g15 auto, what do you reckon?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
dun understand ur question ar bro... u mean what exhaust piping size should u use for 1.5L engine??... 1.7" is sufficient... powerzone extractor price, unker don replied u adi.... brandless stainless steel depends on ur luck... some are jz chrome coated... while some arent done with proper measurement on each primary n secondary pipes, hence causing clash of exhaust pulse and losing power...
May i know how much deg for pipercam setting?? I'm mean the best setting... TQ:hmmmm:
mine set to 4 degrees retard...
mark down the setting before dismantling the timing belt lor... when fixing back ur timing belt, recheck ur cam timing, crank timing, belt tension, etc...
421 extractor... s-flow muffler...
biz-da-tech
520
4g15p is using 1.7 inch?
4g13p is wat inch again for the piping ?
how about the brenzen that kent20 selling. his stainless good?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
around 1.65"~1.7" is ok for 4g13, 4g15...
u mean zenden??... quite ok... but last time i also got hear complain on the chrome coating chipping off... not sure if currently his goods are pure stainless steel or not....
sky i thought auto should be 4-1 for more back pressure for pick up?no?
4-1 will have less backpressure compare to 4-2-1...
my car is toyota corolla seg ae111 1.6 4afe.saya nak tukar clutch plate racing.what brand racing clutch and flywheel can use to my corolla?thank many
