1.8 putra
walao 93na. nice mod you got there.
go pakai apexi airfilter lah since you still pakai the std airfilter.:wavey:
mr. bulat...
for more torque just replace the thr body n clutch first,then follow by other parts which u have been listed,then u will get better response and torque also...but u must think before replace the hi cam,try to find the suitable for ur engine,better ask ur mechanic...gud luck!!
Bump: mr. bulat...
as for the ecu i am using j5 from matspeed!!!! ok la no complaint!!!......i just did my gear box final drive 3rd and 4 th gear!!!! wit exedy and lsd lock!!! wow that so much diff now!!!!! but still using standard air filter!!!! ha ha ha:hmmmm::hmmmm:...... guys share la wat u done to ur cars!!! i know there alot of powerfull cars out there cause i always kena tinggal at kesas highwat!!!:mad::mad:... have fun modding!!!
bro your gearbox 3rd & 4th gear u did it from matspeed also issit...n how much it cost u ??
bro need help here .. my car jerking when i drive .. and the rpm hardly climb / climb slower ... is there any problems ?? pls help.
fuel supply?? cos my car cluth slipped, rpm climbeb slow but car wont jerk...
if im not mistaken u owned 190whp 4throttle 4g93..correct or not? i can remember where i saw the post. i think in 4throttle thread ..
Bump:
sorry ler i dunno what is 4throttle but i juz know tat im running on 45mm throttle bodies only....
this is a 4 throttle unit... http://www.visionr.com.au/4throttle3.jpg
this is 1 hell of a good unit to use..but u will die of pouring petrol only..even standard 4 throttle engine also consume so much oil
That would be one nice mod if my car was a weekend only ride.
Currently nothing much done to my car except for high-comp pistons from a 4G92 non-mivec engine, port & polish block head, added a fuel regulator as prior to this engine was running lean, metal gaskets for the whole engine to help avoid annoying engine oil leakages.
Other than that cars pretty much stock.
Bump: That would be one nice mod if my car was a weekend only ride.
i hope one day i can fit that ITB to my 4g93 huhu...but cost wise ...mm damn expensive bcoz need standalone ems
Bump: i hope one day i can fit that ITB to my 4g93 huhu...but cost wise ...mm damn expensive bcoz need standalone ems
hehe .... if wanna play with itbs ... we need standalone and a good tuner :biggrin:
