Yeah, i was over there checking that car out.
So this is what i managed to observe, with the help of my dad.
It's got a fresh coat of paint on the outside.
It's seems to be repainted on the inside, the VIN tag has some paint on it.
Prolly no major accidents, as far as noob eyes can tell.
No Type R gear knob, Salesman don't know where the second key is.
Rust stains all over, can't find rust corrosion but there are the copper-ish rust marks near most of the hinges front and back.
The drain hole at the spare tyre compartment seems to be destroyed. i can see thick welding marks around it. Not sure exactly what is it tho, or if it is supposed to be that way, never really checked one to that detail before because no other car ever fell to my price range before :P
Using some China made tyre at the front, seats pretty worn. carpets pretty worn as well.
Wasn't able to take it for a spin tho. Can't really compare.
Pros:
It's cheaper :P
Really low milage. 21k iirc (unless those can be tempered with)
Bump: added, the code is
LA-DC5
ED5-1004434
Type R
S6M2 0C0-NH0
Hi all.. just to share.. i came across this particular car as well.. not that i'm looking for a DC5, just happen that I bumped into this one..
yes it is 'cheap'.. but the condition is less than satisfactory.. had a quick check and the interior parts seems to be not integrated properly.. don't know.. they seem to be not right.. probably car was stripped earlier and put back on. non-original gear knob.. a lot of scratches on the lower side of the door panels.. glovebox loose! engine vibrates quite a lot! mounting kaput? mileage only 21k, cannot be right? 3 back windows (rear and sides) have been replaced with standard colour (not dark). salesman said coz puspakom. wiper hole can be seen for the back interior but no wiper for rear windscreen? is this normal?
i am pretty sure this is a type-r.. but the condition.. aiyahh..
checked out 2 black integras over the weekend, 04 and 05 model unreg.
140ish and 150ish respectively quoted, did not negotiate as intention was to see condition only.
both cars are actually in mint condition, showroom mint I would say, hence the price I guess.
mileage was 20K ish ... did not check brake rotor however as per rev555.
interior is fine, nothing looks worn out.
high level look of the engine - very clean.
preferred of course is the 05 model (facelift one) but tooooo pricey still :slug:
vtec open @ 5500rpm = not a stock ECU......![]()
stock shift point should be 6,000rpm.
if you're buying the car, you should request the seller to replace the player and gear knob for you, as well as any damages from the break in of the car.
some sellers I know, keep the gear knob seperately, worried that it might end up getting scratched / stolen.
go for aftermarket momo knob
trust me ........... you leave the dc5 out in the sun for a couple of hours ....... and then you go in the car, and touch the ori dc5 gear know ........... pssssshhhhhhhhhhhhhh
Raiders of the lost ark![]()
. must search for aftermarket knobs after this. but is the ori player for DC5 is the mp3 type, double din cd player is it?
Eh stock vtec point is 5,800.
I know because my car is stock virgin :P
:wavey:
