what is the BEST BOOST CONTROLLER ?
What about Sard Trigger, i like the beeping sound when the boost reach it's peak, therefore i wont have to view the boost meter.
Greddy Profec is nice too, does the scramble boost button comes as a package?
Sum-dum-fuk : some says that tulang ikan may cause boost spike, is it true? :confused:
dont quite like sard trigger :P lol
nop, scramble button comes seperate, but u can make yourself one :P if i make for u rm100 lolx
ok Thankss ! but.. it look like hard to use it :driver:
any suggest more easily to control boost ?..
thomas from gt auto recommends me hks evc 5. but i personally prefer AVCR
HKS EVC is good stuff too , but err do u really want to spend that much cash on a boost controller ?
if u dnt mind buying it, then its good :)
few things i dnt like about the EVC , errr HKS writer to further play with it ? u have it ? hehehe
bt in terms of accuracy its good, the selenoid has a built in MAP sensor which
enables better and smoother closed loop application. Blitz , Greddy, Sard & Turbosmart , they all read boost pressure from the engine by vacuum hose till dashboard. Only AVCR and HKS reads them electronically using a MAP sensor.
From DSMlink source, it states that, AVCR , TURBOSMART & GREDDY uses the same type of selenoid valves , they come from the same manufacturer, AVCR , TURBOSMART & GREDDY do not make selenoid valves. All 3 uses the same mechanism & 2 wire design.
http://www.demon-tweeks.co.uk/resources/images/zoom/AETFG-EBOOST-40.jpg
http://www.clubrsx.com/graphics/00000001/APE-499-X003.jpg
http://carworks.gr/online/images/stories/parts/greddy/greddy_profecbspecii.jpg
ahak and those Draggers who want to use Trigger button on steering or etc
HKS EVC has it optional i tink around rm500
Greddy profec b also has it around rm450 bt can diy rm 5 ?
AVCR errr has it u just got to DIY normal switch rm5 ?
blitz DSBC ? i dont tink there is a trigger
about Turbosmart Dual Stage, there is a trigger comes with unit
about e-boost 2 has triggers too
but greddy is the most advanced trigger over here although its cheaper than the HKS cos its wireless
i seriously hav no idea that it can be done by our self in such a simple way. i mean bout the trigger switch. it means that u can hav any design of the button that u want rite. correct me if i'm wrong.
its just simple wiring
like greddy wiring, u jst need to ground a cable with momentary switch from jalan pasal to switch from low to high boost
avcr is the same , u just need to ground a cable to the white wire (if not mistaken) to enable scramble boost
turbosmart e-boost will have similar setup to just ground them
but so far i love the design of sparco scramble button :P , can buy from N1
http://www.horsepowerfreaks.com/viewimageresize.asp?w=252&p=Sparco&f=Steering_Wheel_Accessories_External_Horn_Button_Kit
turbosmart e boost 2 price is cheaper than the evc5, around same price with avcr or might be cheaper than it and its also side by side with the blitz dual solenoid spec R if im not mistaken... im taking the 45psi version to do comparison.
for those who use manual boost controler. wanna do trigger button for scramble is superb easy... just loop a bypass frm your existing boost controller to the 4age aircond idle solenoid. wire a 12v signal to it and ground it via a switch positioned as u like. set your hi boost and there u go. hi low boost with kampung style trigger function:thefinger:
:confused: about the boost controller......
hard to learn...wiring ..blalalalala:stupid::banghead:
turboXS quad got 4 trigger switch,can be triggered by gear positioning sensor or just make 4 trigger switch trigger when ever u like or make it RPM based huhuhu gud for front wheel drive for traction issue
ok thanx for the info. will try it soon...
