i've reply u by PM...pls check...thxi need replacement for my semi racing excdy..clutch plate alone that is to b install into a 850kancil l2 charged by td04...pm me the best price plus postage to sabah tq...urgent
~for 4g92p how much? for semi racing and racing clucth... plus post to KEdah how much? how many day i can get mine if i order it?
Bump: ~for 4g92p how much? for semi racing and racing clucth... plus post to KEdah how much? how many day i can get mine if i order it?
bro...ur 4g92 is running wat gear box? urs is mivec or mirage na..? or local 1.6 sohc? wat clutch u prefer? wat engine status u in??....u can contact me at 0125206007/0165449556 bryan (no sms)..thx
im running on normal 1.6 sohc from proton... 8" if im not mistaken...
hello bro im transplanting sr20det and planning to use sr20de p11 Fwd gearbox. im using my car for daily and normal road drag if i feel like it. just need your opinion on what 8.5" clutch best fit with my driving. How much will that be for both clutch and clutch cover, im in kl btw. any branch here.? pm me for the info and price.
hye bro....just a quick question...
for olskool car u have stock for racing clutch??
im' using a datsun 120y modified ori engine with weber 40mm and looking for a suitable semi/full racing clutch..clutch oredi slip and got smell like burn brakepad....can u help me sort this out and wat is ur recommendation ??? thanks in advance..
Hi bro... I m using a 4G61T engine wit stock Mirage GB. I've juz roasted my plate till gone edi. Now my clutch slips alot n badly. I tried pop my clutch on 1st gear n my car did not stalled. I m not sure wat size is my flywheel or my clutch plate. Wat would u recommend me??? I juz 1 a normal decent gud clutch plate. not too expensive 4 sure :) Pls PM me ur best price include postage. Thanks
bro, im running on GSR and using ori gsr gb locked to FWD...
i wanna try out BR racing clutch...
can u quote me...? im not sure bout the ori size of the clutch...
wat are the things i need to change...?
clutch, pressure cover and flywheel...?
Bro BR,
Im driving vr4+evo engine with mild mod boosting at 1.5bar max.Can u recommend me which setup thats is good for me.Im from Malacca.If possible with pricing also.
rgds
pijulrs
Bro,
I'm driving a MYVI with K3-VET engine. The gearbox i use back my manual transmission from my original engine. Can you recommend me the best setup to encounter this problem? Quote me the price including delivery to Kuching.
Thanks,
chris
hello br,i need a uprated clutch/flywheel for Daihatsu HD-EG Detomaso engine,can you pm me cost?
Similar threads | |
