whahahaha... yesterday my fren told me about this. he said maybe can put the silicon rubber thing x2, so that the spring will not travel down as much it should. Coz normally plp put 1 only but still got the same issue.... whahahahha..... i terus pengsan
champion la... ahahha...m'sia boleh!
the rubber is just meant for preventing the spring to max out and hit each other ...only as sort of protection to the spring only, if bounce too frequent wit pressure on the rubber, the rubber also
will worn out in no time...
bro, i've from a friend that ACE Tech at seremban can repair/customize absorber.
they can make how hard the absorber as you like. I'm thinking to go there also.
hv u tried them ? just curious how long can the repaired/customized absorber tahan...
cos mostly i heard is that some (service/repair from other area in KL) won't event last for a month...
