Hi Dreamboy,
I wish I can offer my help but I did not fit the meter myself. I sent in to my mech to fit it. I guess it's not a big hassle to fit it so my mech didn't charge me for that fitment. Probably I'm a regular customer.
Taking the picture of the wiring and the socket will help? If so, I think I can do that for you. But I'm changing it back to Original Meter. FX meter give me false info regardless of RPM or Speed. RPM is still ok...only sometimes it go inaccurate. The speedo is the big problem.
Cheers.
Hi kennix anyway thanks for your valuable inputs
i already draw and read all the pin from Levin meter and corolla AE111 auto stock meter. After everything done will post the diagram share with all member who want to used back stock meter on his beloved 4A-GE 20v BT he he....now still busy with my engine swap......
no time to draw nicely just simply sketch out he he…..
the speed cut is control by ECU right? The stock Speedo is drive by cable and the other 2 pin out wire is go to ECU izzit? its that both wire is for ECU reading the speed and perform speed cut??? :hmmmm:your guys input are much appreciate
