emanage tuning and installation
i just install a regrind camshaft,do i need to adjust my adjustable cam pulley and my e manage.fyi i'm using waja 4g18
Bump: i just install a regrind camshaft,do i need to adjust my adjustable cam pulley and my e manage.fyi i'm using waja 4g18
Hi Joshua,i planing to install e-manage or safc to my 4age svt.but i heard fr sumwhere bout it useless on 4age.they say watever u increase or decease fuel,the stock O2 sensor always recorrect signal to stock ecu,izit real?im not sure,cos also heard fr sumwhere.what the price for e-manage+install+tuning?N juz tuning safc?bro,the best afr?may i know the range how rich or lean will damage the engine,below 10afr or above 18afr?thanks for ur time,Joshua.
Hi Bros,
Any Idea where to do Emanage blue tuning and installation in JB area, Heard there is a shop in Pasir Gudang road. Any contact?I want to do installation and tuning for my new vios:hmmmm:
Bump: Hi Bros,
Dear sieokl.
1.Permas Jaya and see the tuner at there. It's have two performance shop Vis and another one forgot la... Sori.
2.In perling RMD Garage. Beside the Shell Petrol Station.
3.The Toyota tuner u can go to Taman tun Aminah Nearest at Plaza Plaza Tasik That the tuner of toyota.
4.Go to Speedwork At Johor Jaya. At johor jaya mana tuner for emanage.
5. Want's buy emanage call me.Heeeeeeeee
Bump: Dear sieokl.
Dear sieokl.
Bump: Dear sieokl.
hmm i didnt noticed that taman tun aminah have a toyota mechanic..what is the workshop name?
is it rmd that was located at jalan kempas,behind a double storey house?
Bump:
Hi Bros,
Bump: Hi Bros,
have u install e manage already?
should be no probs la..no probs like that should accur if its clamed to right voltage and tune from there..no probs so far..
price plus install ing harness etc..rm1550..totall if just dyno tune afc is rm200...
should run afr 12.5 for n/a on full throttle..idle 14.5 then cruize 13.5 like that ok d la..
most welcome..no probs :)
to mr joshua and all sifu here.....i plan to install piggyback on my kancil wif L5 JB-JL 4 piston turbo engine.....hope you can help me with my decision....
1. wich one is suitable...emanage, safc2 or safc1...coz what i heard from other kancil users safc1 is enough as we dont have TPS...so they said what the point of going better piggyback than safc1...?
2. what is the function of TPS.....because L5 dosent have TPS so it can't use full potentional of the emanage/safc neo/safc2/safc1.....from what i understand...if got TPS for example can set 16x16 airflow adjustment (emanage) but without can use 16 only... or something like that laa...correct me if i am wrong
3. just went to one of well reknown shop at sunway and they said L5/L2 dosent need ignition harness of install emanage....with basic harness is ok d....is it true....
thanks a lot...of mr joshua and all sifu here can clarify this issue....
p/s: mr joshua..where loc of your shop...? interested to meet you and install emanage there...:driver:
Bump: to mr joshua and all sifu here.....i plan to install piggyback on my kancil wif L5 JB-JL 4 piston turbo engine.....hope you can help me with my decision....
3. just went to one of well reknown shop at sunway and they said L5/L2 dosent need ignition harness to install emanage....with basic harness is ok d....is it true....
vteckiller,
i PM u just now but failed due to ur inbox full edi...
plz pm me back once see this message.
thanks
Bump: vteckiller,
thanks
Bump:
Juz got my EMB install, But sadly tunner told me that better dont install Ignition set. Coz he try to install old vios it will burn fuse and coil. The engine ignition will become not stable. So now on EMB only air flow tune.
But any bro come to this, is it true that ignition set cant be use for vios?
im using EMB on my 4agze. when i plug in the ignition socket, my car wont start. why is that? Injector n AF is ok
Hi Bros,
Any Idea where to do Emanage blue tuning and installation in Ipoh area. Any contact?I want to do installation and tuning for my fren MIVEC
Bump: Hi Bros,
Hi Bros,
Bump: Hi Bros,
many workshop can install in ipoh..but for tuning..better go dyno la bro..better result than on the road tuning..
mivec wira or waja?
Bump: calling 4 bro joshua....:itsme::itsme::itsme:
SHop is at:-
millennium motorsports asia
no11,jalan pjs11/24,
bandar sunway.
it is same row as hankok tire shop very close by to n1..
yes the emanage can be used in the l5 and l2..no probs..the ingnition harness also can use no probs..but have to mod the stock ecu..no probs at all..
if u want basic also can..if got ignition better coz can boost higher so can retard timing up there..
price plus mod ecu plus ign harness can do special rm1550 for your car...
if dont want ignition harness RM1450 can do for u..
the price includes instaltion,emange,plus dyno tuning...
cheers:)
joshua..
btw
GONG XI FA CHAI
Bump:
mivec wira or waja?
ipoh no idea la..
if u come to KL i can install and dyno tune for u la..
no probs at all..
RM100 for instalation
Bump:
vteckiller,
thanks
Bump: vteckiller,
thanks
sorry my pc delete all then 10mins later full d..
haiyoo sorry yah..
u can email me at :-
ralliart98@yahoo.com
okay...
bro joshua...:itsme:
my e-manage installed..i need 2 know the charge 4 tunning the e-manage..
rm???
hope 2 c u tuning my kelisa after i bolt-on-turbo the engine.. :biggrin:
need sum healthy horse..hehe..
c around bro..tc. :adore:
Bump: bro joshua...:itsme:
rm???
thanks joshua......
but still need to know about the TPS function as L5 ecu dosent have like others.....:stupid::adore:
Bump: thanks joshua......
bro joshua... can emanage blue + ignition harness be installed on lantis 1.6 n/a engine?? i;ve changed to 1.8 n/a block and soon will BOT it with stock BPT turbo... can i use 1 bar map sensor instead of the 3 bar (no money laa..hahaha).
quote me ur price...
Bump: bro joshua... can emanage blue + ignition harness be installed on lantis 1.6 n/a engine?? i;ve changed to 1.8 n/a block and soon will BOT it with stock BPT turbo... can i use 1 bar map sensor instead of the 3 bar (no money laa..hahaha).
does the rm 1550 includes map sensor?
dont not included....greedy 3map sensor sell seperately at rm350nett...
thanks joshua......
the TPS dont function as other TPS...cos L5,L2 TPS signal just read open and close..BUT CAN BE CUSTOM 2 RUN THE TPS....BY MILLENNIUM MOTORSPORT.. :wavey:
heheh kenji reply for me..
its millennium's wire man...
Bump: heheh kenji reply for me..
Write your reply...
New Posts
