ENGINE SHOTS!!!show off ur engine here..
my standard S4PH engine.. pls dont kill em...
better put heatsheid or change the position of ur mushroom heat..:redface:
Bump: better put heatsheid or change the position of ur mushroom heat..:redface:
helow, mind if i share?
there's a lot post for 4g63 / 2jz / rb / sr / b head / h head...
i think this one would be different...
not mine, but my friends..
i shot this for him~
¬¬Engine:
350CID Small Block V-8
Custom Bored 5.7L – 5.9L
Black Forged Piston Set
Black Gapless Piston Rings
Comp Cams Racing Camshafts
Comp Cams Racing Lifter Kit
Custom 90-Degree vertical Straight Open Exhausts System
Edelbrock Polished Aluminum Cylinder Heads
Edelbrock Dual Carburetor (700cfm)
Edelbrock Carburetor Calibration kit
Edelbrock Racing Valves w/Custom Valves Job
Edelbrock Roller Rocker
Edelbrock Racing Valve Springs
Edelbrock Water Pump
Edelbrock Nitrous Wet-Shot System
Weiand Supercharger 6-71
Trick Flows Push Rod
Sealed Power Main and Rod Bearings
Sealed Power High Performance Oil Pump
Summit Racing Street Scope Intake
Summit Racing CDI system package
Summit Racing High Performance 140A Alternator w/Custom Pulley
Summit Racing steel-braided coolant hose
ATI Engine Torque Dampener
Autolite Iridium Spark Plugs
Mallory Distributor
Mallory Promaster CDI Coil
Pertronix Complete Ignition System
Accel Spark Plug Wire Set
Power Master Torque Starter
Proform Timing Gear
Titan Copper Head Gasket
ARP Head Studs
ARP Chromemolly Rod bolts
FAL Aluminum Performance Radiator
FAL Twin High Output Cooling Fans
FAL Overflow Tank
B&M Chrome Steel Oil Pan
B&M Auto Trans. Megashifter
March Performance Billet Water Pump Pulley
March Performance Power Steering Pulley
March performance Billet Alternator & Power Steering Brackets
Billet Specialties Water Neck
Lokar Engine Dipstick
Lokar Transmission Dipstick
Lokar Throttle Cable
Lokar Kickdown Cable
Lokar Aluminum Pedals
Lokar Aluminum Handbrake
Fram High Capacity Oil Filter
Billet Specialties Oil Cap
Billet Specialties Breather Cap
Billet Specialties Radiator Cap
Billet Specialties Valves Cover
Russell Steel-Braided Hoses
Drivetrain:
GM TH-400 Automatic Transmission
B&M Racing Torque Converter
B&M Racing Transmission Overhaul Kit
Ford 9” Rear Axle
Moser Engineering Drive Shaft
Moser Engineering Rear Axle Shaft
Moser Engineering Rear Axle Bearings
Summit Racing Transmission Cooler
¬¬Engine:
Mallory Distributor
Proform Timing Gear
ARP Head Studs
FAL Overflow Tank
Drivetrain:
Ford 9” Rear Axle
holy engine! :adore:
my associate's :rofl: rojak engine!
+ moves like :slug:
and blown to kingdom come! because :rofl:
my new engine
(actually aledi in the engine bay )
hello all :itsme: here just want to share me and my friend waja engine bay 1.6 sohc 4g18p:biggrin:
my engine bay from 1.6 sohc 4g18p become 4g18T
http://photos-342.friendster.com/e1/photos/24/36/41606342/1_953179629l.jpg
my friend engine bay with 1.6 sohc 4g18p
akai....spray the radiator hose to red...even the clip also...kehkehkeh.....the paint stick or not? :hmmmm:
your engine bay is really nice wajarays~:top:
its not campro turbo bro ... its mitsubishi 4g18p 1.6 sohc engine found in 1st model waja ... this is the blue waja you snap the pic at brothers puchong :)
