emanage tuning and installation
hello there joshua..
using bpt with e-manage blue.(first batch..old version)
1. Can setting,dyno tune and update my e-manage?
2. I realize 2 of the wires were cut(by previous tuner)..,can u check wat was wrong with my
e-manage,or is it my ECU?
3. How muc it will cost and how long wud it take?
wud be nice to hear it soon..coz i really need to tune my e-manage by next week.
thanks..
Tuning Tips :-
If your car is N/A try set your target afr at 12.5afr
so if u can get afr at 12.5 from maybe 3000rpm till 9000rpm and full throttle that should be safe and car should make good power.
you can run 14plus at idle and and light cruising.and at half or 3quater throttle target 13.3 or around there la but full throttle try run 12's ok.surely car wont bloW!
About turbo charged
same thing on cruise and etc...but on full boost and full throttle at 3000 rpm to whatever rpm must run in the 11's afr and u'll surely be safe...
surely no blow engines..
but on turbocars u dont add ignition on full throttle ok! leave it ori if original ecu is turbo ecu or u can retard more..
n/a can add bit here and there la..not to much but a bit la..if u are good and hearing at pinging..then u can put more or else carefull..too much will blow your engine! broken pistons...its call detanation! so beware!
cheers
Joshua
Hi there,
What should I adjust/tune after modifying to let coolant temperature goes lower?
At first, the car is a little bit sluggish. After I accidently increase ignition timing 1 degree, the response is back and even better. I wonder if there are other options to optimize the performance.
THANKS.
just only noticed this topic... i have a question to ask.. here's my car dyno graphs... compared to stock standard... i have done up quite a number of mods, all mechanical.. no piggyback or any electronics yet...
looking at the the A/F ratio... i wonder will i get still improvement after installing E-Manage? how much would i get?? worth the money or not?
advice and feedback would be appreciated. Thanx!
http://img523.imageshack.us/img523/105/dynocomparisonstockvsstal3.jpg
hi josh, can install emanage to my cald. but i only hav the af harness. izzit gud to hav the ignition n boost harness too? if do pls inform me...
i soo newbie to this thingy
yes can be done la..no probs :)
hi,sifu vteckiller,can install e-manage ultimate to my l200s?it is already been upgrade but i only use safc2..i just have basic harness,and the software cd..
and of coz the main unit..hehe...some of my frend said can for the blue one but not sure 4 ultimate..
not sure about ultimate coz i have never installed in l200s but i am sure can be installed la..
but the blue one is much easier and can be done..and save cost..after all u dont need to use ultimate coz most of the functions u wont use anyway..
can do for u...rm1550 only plus install and dyno tune for your l200s emanage blue.+ignition
rm1550?but i already bought the ultimate..how much cost to install?rm1550=install and dyno?
Bump: how about avc-r?can tune up for me
install untimate is very ex la..
rm250 to install and rm300 for dyno tune la..so total rm550 la..
the avcr i can tune for u foc la no probs la..
cantikla bro..i think about next week i'll be at sunway..
Bump: need to buy ignt harness also?
jo, how much u charge to change injectors and dyno tune emanage for mazda BPT?
our emanage dyno tuning fee is RM300..
changing the injectors we can do it for foc if u bring them along..no probs :)
1) emanage blue + ignition harness + instalation + dyno tuning = RM1,550
2) dyno tuning RM300
3) dyno tuning + injector cleaning (ultra sound) + flow testing injectors RM400
Bump: 1) emanage blue + ignition harness + instalation + dyno tuning = RM1,550
vteckiller, do u have any distributor or frens who helps to tune e-manage blue over Sabah ?
Bump: vteckiller, do u have any distributor or frens who helps to tune e-manage blue over Sabah ?
sorry bro i dont have la..
but i got a friend in tawau who sells them la..but not sure if he tunes or not..
elo bro jo,
i already have emanage blue installed in my wira 4g93p and would like to know how much do u charge for dyno tuning plus setting my fuel pressure regulator and the adjustable campulley..
thanx
elo bro jo,
thanx
it will cost u rm300 for tuning and setting fuel reg and distributor/timing,etc...
all in all total of rm300... :)
Sifu..
What good item to install
& manage evo 1 engine..
Bump: SIFU..
WHAT GOOD ITEM TO INSTALL
& MANAGE EVO 1 ENGINE..
