6A12 Vs 4G91
u think 6a10 produce more heat?? wait u see mivec when raining day my car bonnet produce vapor when rain dropped on my car bonnet. everyone look at my car when i was driving
Really...?
Is this have anything related to Engine Oil type or Coolant system..?
Bros..
Is there any new Drive Shaft PNP to 4G91 cause asked some sparepart shop and they told to find it at Halfcut..
Issit true that most engine part for example oil sump gasket from 4G92 1.6 M'sia can PNP to 4G91..?
i'm using mivec also. and it not that heat. i still can touch cover rocker after 2 hours drive. check your engine details bro, it might cause u some problem 1 day.
izzit drive shaft form mivec is different form other mean the diameter is larger ??coz my accident spoiled my drive shaft and the foreman say is is very hard to find....
Sorry to hear that..
Seemed the accident quite serious...
If 91 can use 4G15 drive shaft, then i think u can use 92 from wira
bro,y dont try my idea:
1)to buy a MIvec 1.6 block-----------------------------RM700
2)Full set 1.8 GTI wiring + ECU+injector+TB+Coil /Disb---RM1500
3)1.8 DOHC Head--------------------------------------RM500
4)air com----------------------------------------------RM200
using back ur Gear box,Air con system,dashboard
all done w/o RM4500 including labour charge...sure power than 4G91/6A10.
if got more budget,change out ur gear box to 1.8 DOHC,change piston ring,metal gasket,polish your 1.8 head(don;t porting,hole 1.8 big enough,if porting more sometime will make power lose)
that is my plan for my car haha...
now i m using 1.8 head,1.8 ECU only.much better than ori 4G91...
plan to buy Mivec block for next project+high cam...
just for your tips to start your project..:idea:
Depending of your budget:
6A10 V6 1.6cc is cheaper of course, but similar to his twin cousin 6A12 problematic auto gearbox, if manual no problem. V6 engine means comfort in top end power of cruise along the highway...no pick up at all compare to 4G91.
4G91 DOHC Durable, good pickup, fuel economy but parts expensive example gearbox, aircond, engine kosong because local evil cousin 4G15 have the same requirement.
4G91 also popular with local evil cousin therefore 4G91 (M) Halfcut always expensive.
Approx RM4.5K to RM5K.
cute one there bro..:thefinger:
local evil cousin = proton...lol :rofl:
who's the local good cousin then....:hmmmm:
Thanks alot for the info bro.. :tee:
bro,if u want sell ur 4g15.i am quite interested coz i want convert my satria 1.3 to 1.5
Write your reply...
