ACCESS by BLITZ ecu..
glanza
kl/kelate
anyone knows about this ecu? FYI, i use in my 20V but i dunno what is the features about this ecu.
is it disable speed cut? what is the different between stock ecu? can tune or not?
on a 20V, i not sure la abe.
on a starlet, it's mapped for 1.2bar, 8000rpm rev limiter, and no speed limiter.Plug and play,tuned for a fast road set up.
definitely no speed cut.
i am using this ecu for my 4age 20v BT also..glad to know someone is using this ecu...i thot i am the only one using it...gosh...i cant find anything abt this ecu also pertaining to 20v set up.... from wat i discovered...no rpm cut..speed limit cut... it raises fuel pressure from standard 20v which is 29 psi to 33 psi ....
call me bro...
kris @ 016 8301909:listen:
fuel pressure naik ke 33 psi...ori dier 29 psi....i ingat ecu ni d pakai utk BT tobo ....
wow...no rev cut r.....good luck for the rare ecu....as i knew oni SVT got multi performance ECU like tom's n TRD
Anyway dont whack ur car till no limit RPM...danger to ur engine unless u upgrade ur engine like fuel pump. AFR, feul pipe n etc.....:driver:
just my 2 cents
anyone got extra blitz ecu for sell?hahahah i want one......
call me bro...
how the hell can an ecu raise a fuel pressure???
