port and polish
skywalker, did u took the first pic of the ported intakes ?
tat is real beautiful
Cut by machine ? dun look like hand port
cut away the valve guide. will the valve vibrate when it moves up and down??...
i wouldnt risk it having damaged valvetrain jz to improve abit of the air flow inside....
i got the same answer when i asked why dun cut the valve guide
but i still tink the oni way to find out if the valve have problem a not is to cut it n try :hmmmm:
Quite a few 4AGE's and G13 Gti heads are still running daily without problems so far. Vibrate? Not sure. Its situated quite deep in the head.
yeap... first pics is ported by cnc machine... not done my local... i got the pics from internet anyway... http://s.lowyat.net/style_emoticons/default/tongue.gif
u wanna take the risk??... http://s.lowyat.net/style_emoticons/default/rolleyes.gif
dont forget you must got art to porting and polish
the art... http://s.lowyat.net/style_emoticons/default/brows.gif
true??... http://s.lowyat.net/style_emoticons/default/hmm.gif
PnP with cnc machine... Very accurate and precise one.
wat kind of bukit? behing my house got a bukit. that bukit lor. haha..........
then u will also notice that ur fuel gauge very cepat goto E. haha..........
BuKiT KemBaR.....?
can we obtain same result with manual p&p compares to CNC m/c ??
anyone? coz CNC damn xpensive lor
But IMO, there's only a certain extent CNC can do its job which still requires porting by hand. A bit of inaccuracy or carelessness in initial measurement could jeopardize the port work? No kah?
yeap... thats why we have bench flow testing... for a common engine, the specs needed to pnp a cylinder head is already tested hundreds of time thru R&D...
but for a new engine, bench flow is needed to try and error on whats the best spec for that particular engine...
Sifus, could you share with us which professional workshops that have a flow bench & high precision porting tools that also guarantees improved airflow?...i'm afraid most of us only knows of Powerzone & Matspeed where other alternative tuning w'shops would also be useful for our future reference...many thanks...
