- Joined
- Feb 19, 2006
- Messages
- 166
- Points
- 1,516
errr.....what car ah??? if proton cars, i think in this tread already got some pricing leh
for satria.........
Hi, evan2000.
Suitable for car 1300cc proton wira a/b kah?
currently, using performax asb & performax sport spring as well. Almost a year time. Think to change a set of adjustable asb. Should Titan cost cheaper for car 1300cc?
That sound means that you inverted monotube is about to go or is gone. You'll need to send that to be serviced. It will be more pronounced if its on pillowball mounts. Its the inner seals and the piston sides rubbing on the tube.
Get that serviced and I'll be a good as new
HOw does this Titan vs hotbits??
Thank you
h2zero,
titan does not have TUV approval whereas hotbits does. also, hotbits's boss is an engineer by qualification and uncle richard isn't (just to compare qualifications that's all). hotbits has a larger staff compared to titans which is often if not always understaffed and have limited workspace.
although i'm a titans supporter BUT from my current understanding of both companies, build quality (ie. machined parts) are similar BUT titans is not as good in documentation compared to hotbits.
