TE71 Coupe Project Sharing
New Engine in engine bay and running:
well done chu.... evrything going well n nicely done ;-)..... can't wait 2 c d engn perfomance n d car as well....
cool!!! 7A is running!!!
how's the power bro?
Power? running without exhaust, only got extractor.
Rev not more then 2.3K RPM. How to feel the power?
Going to do up the exhaust this saturday, then after that, Run in.
Still cannot test the power.
actually by cromming the valve cover look nice..mayb will do on that..but how abot eng become more heat..is that true..
oh! then how many torque can this 7A produce?
Donno......just done up the exhaust only.
The cam degree is out of spec, I believe most of the powerband already shift to 5K RPM onward due to intake and exhaust cam being advance more then 5 degree.
After run in only can test actual power and proceed with fine tuning for the cam degree, set the proper AFR and reset the ignititon timing.
bro can i noe wat flywheel u r using??? as far as i know,4ag flywheel cnt b use in 7afe engines.. r u using back the 7a flywheel?? n can i noe wat timing belt u r using??? appreciate yr tunjuk ajar
the cam degree is out of spec? wat's that mean?
running high cam with ur 7A?
use back 7A flywheel. u can try porsche 944 timing belt
when u run 7A, u cannot use back stock timing belt because the block is longer. So after we change to other timing belt, the cam pully won't sit back on the original cam degree, it's out of spec. You have to use adjustable cam pulley to correct it back.
