is it possible to use 1.6 injection kit for 1.3 carbie?
motorhead2000
to all sifu at 0-100.com
just asking 1 question...can i used 1.6 injection kit for my 1.3 carbie?..some people said no because different 'tapak' intake manifold...is it rite?
if i change the intake manifold to 1.3/1.5 efi, can i use 'rojak' with the others 1.6 kit such as ecu, wiring and etc?
thank u
useless la bro..unless u already heavyly mods the internal.
if stock std why u want to waste petrol?
thank u
Yes it is possible coz i've ran a few people doing this mods especially to 4g15p. I think it is also possible to do it on a 4g13p since both the 1.3 and 1.5 doesn't differ much. I myself am going for this mod for my 4g15p.
The tapak for the intake manifold for 1.6 is different from the 1.3/1.5. That is why u need a 1.3/1.5 intake manifold for this conversion.
Next comes the throttle body (t/b). According to my mech, u can use any t/b
as long as it came from a sohc engine. This includes 1.3/1.5 sohc, 1.6 sohc, 1.8 sohc or 2.0 sohc. The higher the cc, the bigger the t/b size will be.
To be on the safe side, better use the 1.3/1.5 ones. Bigger/bored t/b is to be used when upgrading.
Then the injectors. For good fuel consumption u can use 1.3/1.5 injectors. 1.6/1.8 injectors is an opt for upgrades.
Then of course u need the 4g92p (1.6) engine wiring, ecu, airflow sensor, injection fuel tank (any injection model - 1.3/1.5/1.6/1.8) and a 4g13 injection distributor.
Most importantly is a mechanic that is familiar with this mod and another important thing is to tune the air, fuel and ignition setting to match the engine.
Expect to gain an increased power and fuel economy due to the more efficient fuel injection system compared to carbs. The gain is also dependent on the a/f setting.
Hope this helps...thanx!
