http://www.zhapalang.com.my/Zplpicture/automotive%20lightling/superled/1.jpg
Tired of the stock yellowish filament bulbs on your car?
Looking to replace these filament bulbs?
* LED is the solution.
* LED light bulbs provide dramatic energy improvements compared to your stock filament bulb. LED bulbs consume less than 20% power of filament bulbs and they are very energy efficient. LED bulbs does not become hot fast like filament lamps.
* LED bulbs also have a faster response time compared to filament bulbs.
* LED bulbs also have a long life expectancy of 20,000 hours onwards.
Description
* These low profile LED bulbs provide excellent brightness for your various needs.
* Brighter than conventional multi LED bulbs.
* Excellent forward viewing angle of 120° compared to normal multi LED bulbs (~90°)
* Most suitable for Front Pole Lights, License Plate Lights, Speedometer Lights, Side Turn Indicator, 3rd Brake Light and any other applications using T10 Wedge.
http://www.zhapalang.com.my/Zplpicture/automotive%20lightling/superled/w4.jpg
http://www.zhapalang.com.my/Zplpicture/automotive%20lightling/superled/b4.jpg
available: white and blue only
Technical Specifications
* Each bulb consists of 4 Super high flux LEDs which are brighter than conventional LEDs.
* Power Rating 0.5 Watts.
* Direct Replacement for all old filament T10 bulbs.
* Operates at 12V ( for automotives) with polarity protection. If the bulb does not light up after install, simply reverse the direction.
* Viewing angle 120degrees
* Physical Dimension 18mm(Length) X 10mm(Diameter) X 9mm(Wedge Base)
* This is a drop in replacement bulb for W5W 147 152 158 159 161 168 184 192 193 259 280 285 447 464 555 558 585 655 656 657 1250 1251 1252 2450 2652 2921 2825 bulb codes. Please refer to product dimensions and cross reference to your existing bulb to ensure you are purchasing the correct bulb size.
http://www.zhapalang.com.my/Zplpicture/automotive%20lightling/superled/LED4fluxDimension.jpg
Comes in All New Plastic Wedges!!!
Length 18mm
Base Width 9mm
Top Width 12mm
Base Thickness 2mm
price count per pair rm25
note* we will tested it before we ship so 100% working
# Delivery: shipping charge rm5 for peninsular malaysia
# shipping charge rm8 for east malaysia
p/s mass order within 500gm will remain the same rate
Description
Length 18mm
Base Width 9mm
Top Width 12mm
Base Thickness 2mm
