ZTH Toyota Owner's Gallery
d only question remains.... should or shouldnt i put decal designs.. sigh..
it's gallery section.. not spec section.. d stats and figures arent important.. dis car is strictly poser.. nothing fast nor furious... engine bay? hehe... not even worth takin pics
blackhowling change colour already oh... last friday i saw a orang supra in original kayu.. i dunno is u..when i walk to there wan see see supra...saw a orange supra lari liao....then i continue watch other supra....
kakakka so many monster car there...
forgot to said..today got ppl told me he saw me in original kayu and then told me blackhowling change to orange colour..so i just know it....kekekekkeke
LOL, so I'm guessing you're running a 2JZ-GE then?
2JZ-GE ? heh heh heh....
ppl's car is like a nuclear warhead... dont need specs to know how much damage it will do when drop onto KL city. ;)
Having a 2JZ-GE doesn't make it a warhead. It's the 2JZ-GTTE that does.
i thought it is 2JZ-GTE? not 2 t's?
ozX...
mate... what's ur opinion bout this sexily front bumper?!
note:
this is not my car... i have 1WD... manual power plant -> my sexily bmX... =P
Most 2JZ engines are twin turbo, but some later models were single turbo though.
ozX...
note:
It doesn't look too bad, but a nice front on pic would help.
All mk3's are wide body, except for the GA70 mk3, but it did come in a wide body shape later.
OzXchange: never has toyota made any single turbo 2JZs... are u really that knowledgable with 2Js? if u wanna know more about 2jzs... go to Supraforums, MKIV.Com Home of the MKIV Toyota Supra or the TO4R.COM
did yr 1JZGTE supra ever came in single turbo in stock form? i doubt so.. coz it was never produced in that form.. neither did 2JZGTE... ;)
2JZ-GTE Engine Specifications - Japanese Domestic Model 5/93 - 8/97 InductionSequential Fuel Injection, Twin CT-20 Turbochargers (Sequential), IntercooledValves 24Camshafts2 (DOHC) Intake Duration224°Intake Camshaft lift7.88mmIntake valve diameter33.5mmIntake Valve timing - Opening3° BTDCIntake Valve timing - Closing50° ABDC Exhaust Duration233°Exhaust valve diameter29mmExhaust Camshaft lift8.4mmExhaust Valve timing - Opening52° BBDCExhaust Valve timing - Closing4° ATDC Bore x Stroke (mm) 86 x 86Capacity (cc)2997Compression Ratio8.5:1Maximum Power206kw @ 5600rpm (280HP)Maximum Torque435nm @ 3600rpm (320ft/lbs)Redline6800rpm 2JZ-GTE VVT-i Engine Specifications - Japanese Domestic Model 9/97 - 07/02 InductionSequential Fuel Injection, Twin CT-20 Turbochargers (Sequential), IntercooledValves 24Camshafts2 (DOHC) Intake DurationvariableIntake Camshaft lift7.88mmIntake valve diameter33.5mmIntake Valve timing - OpeningvariableIntake Valve timing - Closingvariable Exhaust Duration233°Exhaust Camshaft lift8.4mmExhaust valve diameter29mmExhaust Valve timing - Opening52° BBDCExhaust Valve timing - Closing4° ATDC Bore x Stroke (mm) 86 x 86Capacity (cc)2997Compression Ratio8.5:1Maximum Power206kw @ 5600rpm (280HP)Maximum Torque455nm @ 3600rpm (335ft/lbs)Redline6800rpm 2JZ-GTE Engine Specifications - Export Specification InductionSequential Fuel Injection, Twin CT-12B Turbochargers (Sequential), IntercooledValves 24Camshafts2 (DOHC) Intake Duration233°Intake Camshaft lift8.25mmIntake valve diameter33.5mmIntake Valve timing - Opening3° BTDCIntake Valve timing - Closing50° ABDC Exhaust Duration233°Exhaust Camshaft lift8.4mmExhaust valve diameter29mmExhaust Valve timing - Opening52° BBDCExhaust Valve timing - Closing4° ATDC Bore x Stroke (mm) 86 x 86Capacity (cc)2997Compression Ratio8.5:1Maximum Power238kw @ 5600rpm (320HP)Maximum Torque428nm @ 4000rpm (315ft/lbs)Redline6800rpm
btw... mine's a 2jzgte... single turbine...
A thread every 60 seconds
