Myvi with honda big brake kit rotor
WilsonTHarv
Jul 14, 2016
18
Hey there everyone , i got a myvi that i have installed big brake kit taken from Honda FD2 , everythings was working fine .
Now that i need to replace my worn out rotor , i wondered if there is any rotor that would plugnplay into myvi with honda FD2 brake which the lug pattern is 4x100 ... ori honda rotor is 5x114.3 which would require redrilled to fit into myvi hub .
Many thanks for any input :)
It all depends on how your BBK was installed. Was it installed by just custom fixing the caliper onto the stock Myvi rotors? Or did you swap everything out? If you swapped everything out - you'll need to swap back to a FD2 rotor and custom drill those holes. Or find a 4x100 rotor that has the correct depth and size to pair with your calipers.
WilsonTHarv
18
It use the caliper & rotor from Honda FD2 .
Custom bracket to extend the mounting hole from the honda caliper to Myvi knuckle .
a FD2 stock rotor would fit but require drilling as stock FD2 hub use 5x114.3 PCD , while Myvi use 4x100 PCD .
Stock Honda FD2 rotor is 282mm , thats the only thing i know , i didnt have the source to compare rotors to find out which rotors from which car have the same dimension as the stock Honda FD2 ones but with 4x100 PCD
I'am trying to avoid having to drill my rotors everytime it need replacement so i posted it here to see if anyone might know whats the rotor & from which car i need to have a fully plug and play setup without the need to drill the rotor ...
Actually i'm not too comfortable in drilling brake rotor also la ... so i'm trying to avoid it if im able to . hehe =p
mADmAN
1,840
547
ur outta luck. no choice but have to drill. closest option is a rotor from a mini which is 4x100 but its 280mm if i remember correctly.....and not sure if available in malaysia
u could also get Prelude BB1 or other H22a equipped car rotors which are 282mm and 4x114.3. then drill to 4x100. though need to check the depth of the tophat.... as well as the center bore.....should be the same as honda tends to use same specs/parts for their cars across multiple ranges.
no worries if drilling if done right... i used to have prelude BB1 rotors on my EG hatch redrilled to 4x100 and bring it to track days etc and its fine.
Personally, I'd consider redoing your setup if drilling holes is your concern. Fit new Myvi 1.5 rotors, remeasure the caliper distance and redo the caliper bracket to accommodate Myvi 1.5 stock rotors with your FD2 calipers.
In the first place when you did the BBK should have fitted one that does not need re-drilling. Looks like bro. Izso recommendation is better for long term use....
WilsonTHarv
18
Yup , according on google search i saw Mini,Accord/Prelude rotor was within specs too ...
Sigh guess there is no way i can get a rotor to plugnplay in my kind of setup .
Thanks for shedding light bro =)
I think Myvi rotor would not work with FD2 caliper even with custom bracket as the brake pad surface is way way bigger that what a Myvi 1.5 rotor had .
Yup , only way is to get aftermarket BBK designed to fit this car , but back then using setup from FD2/Odyssey is more cost effective ...
Thanks everyone for sharing the info =)
ixeo
4,788
3,080
KL, Malaysia
You’re stuck.
I’m using EK4 262mm rotors and calipers. Means 4x100 and no drilling required.
Drilling rotors weakens the structural integrity. And you shouldn’t fuck with brakes.
Reactions: Izso and vr2turbo
mADmAN
1,840
547
@WilsonTHarv Ixeo has provided a possible solution. EK4 262mm rotors. Maybe get that 4x100 rotor and refit the bracket to match
if only rotors change, then not a solution... the calipers TS is using is way bigger than the calipers that ixeo is using. unless TS wanna downgrade.
in my opinion, as the car is just a myvi. no matter how hard you touge, wangan, track etc etc, the brakes are more than sufficient as the car isnt heavy and it doesnt reach speeds that would stress the rotors that much.
should be fine in my view. only thing i would recommend is get the 4 hole version and redrill instead of the 5 hole.
the 282mm 4x114.3 Prelude BB1 calipers+rotors would also be a brake kit i would go for if i were to upgrade the pink myvi.... n yes, i would redrill to 4x100 too.
ixeo
4,788
3,080
KL, Malaysia
282mm won't clear Enkei RPF1 rims. So no thanks.
Redrill dangerous, I scared the discs fail them no brakes touge bye bye down the cliff.
WOuld like to know which type of REAR disk brake fits Honda Civic EG local model, currently using drum rear brake.
Option:-
Can Integra DC1/2 disk brake or EG disk brake could fits?
Any recommendation of other rear disk?
Would like to install, when buy from chop shop usually the whole sets consist of what and approximate how much?
Hope your feedback soon..or 012-399 9933
