GT Radial HPX or Hankook V2 Concept 2
chokia15
Oct 4, 2012
43
Kuching
Hi Sifu, am looking to change my tyre size 205/45/16. But not sure whether to select GT Radial HPX or Hankook V2 Concept 2. Please enlighten me. Thanks!!:driver:
Which one is cheaper? Usually GT Radial is good value for money.
Hankook is slightly cheaper RM20 less.. :biggrin:
Then V2 wins bro.
Plus its cheaper, win win lol
Spec wise actually they're in similar UHP category with traction rating both AA.
HPX though has treadwear rating 340 while V2 has 500. Based on this, it seems the V2 uses harder compound and should last longer, but the HPX is softer tire which normally should translate to better grip.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Noted bro! Thanks for the suggestion!! :top:
How much anyway? If u want cheaper and cheerful, Achilles ATR Sport is my top favourite.
RM200-210 for 16 inch. 15 inch depends on sizes are RM140-180.
---------- Post added at 02:52 PM ---------- 6 hour anti-bump limit - Previous post was at 02:49 PM ----------
Theoretically yes. But V2 reviews better than HPX wey.
ATR Sport is 400.
Supra_Fanatics
20,673
3,998
16" just go for ATR Sports. Less rubber I think u might be able to get RM195 a piece or maybe just RM200 a piece.
Since 205/55/16 is RM205 while 205/50/16 is RM200
parakey
1,367
226
Dunno why but going from the data from tirerack.com, Hankook V2 Concept weighs less than other tires. This will help lessen unsprung weight.
Have you check whether HPX have in your size, because many sizes were switched to BAX2, means no more HPX.
V2 Concept 2 is HP all seasons, if V12Evo2 which is summer tyres will be better performance....
chokia15
43
Kuching
Only can get v2 concept2 here.. No V12Evo2 so no choice :banghead:
Dear All,
I need some advice n comments,will it be a good idea for me to install a k&n drop in air filter into my stock standard 4g93p?What are the advantages and the disadvantages?....kindly help,all replies are highly appreciated,thanks!
