Aircond compressor kicks in making the car extremely heavy
desmond0318
467
48
Good day guys.. can i do some survey here?
If your car rev at 2k rpm with neutral gear than you turn on the aircond, how many rpm does it drop?
Mine dropped 700-800rpm if i rev to 2k rpm with neutral gear, but no drop while it AC compressor kicks in when idling.
Things i've checked
1:Throttle body OK
2:AC compressor clutch OK
3:AC control valve OK
Above all was ok, so what is KOing? :adore:
enjin
Jan 29, 2014
13
2
503
i believe u running on older car model. it didnt happen overnight right? if that the case, to cope with it u can do some mod that will increase ur hp. in my case i change the extractor 421, notice the heaviness is reduced when using air con. (not sure how much since i dont hv rpm meter)
of course it just helping to mask the symptom, but i didnt bother since its an old engine. always like that one
maybe, cause i never service aircond system for 4 years d..
Aircon is one of those things that "if it ain't broke... don't fix it". Clean it yes you can do, service no need unless got problem... like now. Might be worthwhile checking your compressor. From 2000rpm drop down to 700 is a bit weird on idle.
But even for me as long as the aircon is turned on there'll be some noticeable power 'drain'
If I read correctly, he mentioned idle no problem, only when he rev to 2k RPM, then on air con it drops to 700, but I am wondering why he is doing that?:confused:
desmond0318
467
48
Felt hard to get out from juntion and roundabout with aircond on, not sure how much load when the compressor kicks in.. Why i test like this is because when i driving at 1st and 2nd gear, the compressor kicks in and feel like a slightly touch on brake
---------- Post added at 10:36 AM ---------- 6 hour anti-bump limit - Previous post was at 10:33 AM ----------
yea bro, i also think the same, as long as still cool no reason to border with it :biggrin:
---------- Post added at 10:50 AM ---------- 6 hour anti-bump limit - Previous post was at 10:36 AM ----------
yea you're correct, but the anonying 1st and 2nd gear feel is still there:mad:
Oh! now I get you. Is more of a drag thing, engine no power when accelerating from stand still. with air con on. But I am with bro. Izso, normally if air con is cold and no problem I rather not touch it.
desmond0318
467
48
yea i agree, really don't dare to touch later alot kacau..
---------- Post added at 07:30 PM ---------- 6 hour anti-bump limit - Previous post was at 07:27 PM ----------
u got grounding cables? if not try getting one installed the HKS purple from Taiwan good enuf bout rm20-25.
Yes i have grounding.. just now checked voltage at battery and alternator as well, no voltage lost :(
seems like ficd is the only choice for small cc's cars to battle with the compressor load :bawling:
But yours from idle no problem means no need ficd....:driver:
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Things i've checked
1:Throttle body OK
My Persona new also like that wor. But when it kicks in, engine felt super heavy and my car will kick back.
D7zul
2,697
848
Shah Alam
Let me guess.. Ur car is automatic, right?
If i were u, i start saving money to buy compressor..
I had an experience.. The compressor getting heavier trough time n suddenly its stop moving
Smoke comes up coz d belt still turning but d compressor jammed already
desmond0318
467
48
Bro, auto or manual 1 ?
It's manual 1, i though auto don't really felt that kick in like a brake in because of their gear ratio.
Compressor consider ok no stress twisting it with 1 finger, looking around to service compressor at least having the compressor oil change.. But no workshop do this kinda job :bawling:
i am curious did powerzone offer overhaul service? full engine or head..
coz my engine eating up alot of engine oil...wanna know the price to do it at powerzone..not really wanna send my engine to other ppl.
thanks alot
regards
