is exhaust back pressure a myth?
YYC
1,833
939
Some one from automotive engineering please shed some light. I'm also perplexed.
D7zul
2,697
848
Shah Alam
Back pressure is good 4 low rpm power.. Eg town driving
But 4 racecar like NASCAR they eliminate d back pressure.. Coz their cars aren't 4 town driving :biggrin:
ixeo
4,788
3,080
KL, Malaysia
Exhaust pulse is not back pressure, and back pressure is not exhaust pulse. Look it up.
Backpressure is not a myth, its science. Reduce backpressure on an Evo by changing the cat-back, you will see higher hp OR higher boost OR faster spool time.
hex999
378
57
So is it possible to achieve good low end torque with a straight pipe and a straight flow muffler but with a standard exhaust diameter? least restricted setup. Or "back pressure" is required, thus using a S flow muffler but sacrificing high end powerband?
any engineers can explain? :D
Waiora_ProTuner
619
221
like ixeo said, exhaust back pressure and exhaust pulse is different..
2-stroke exhaust is pulse...
back pressure is not a myth...
back pressure needed for power is a myth..
i'm not an engineer in automotive btw...
cvkit17
2,884
1,354
Back pressure is friction and it is rubbish and not needed. However, flow rate is another thing to discuss as it is governed by the size of the pipe and exhaust air temperature. Back pressure is created when there is something in the way of the exhaust air discharge thus it will negatively affect the flow rate and also scavenging. Too large the pipe and the temperature will drop faster and that would affect the flow rate to drop. The cylinders are not doing the same stroke at a time. Hence the "pulse" is important to keep the system in a harmonic state as the energy from one cylinder helps the motion of another. Exhaust exit too fast, pulse is disrupted thus lower efficiency as scavenging drops. High revving cars do not need this scavenging as much as normal cars do because their pulse is very well optimized for its high rpm range. Kinda complicated thing actually....the most important thing is to get the term right for its purpose. Laymen usually say "back pressure" because they can only understand this. It's like wax and polish.. Some thought that polish and wax are the same thing.
Waiora_ProTuner
619
221
'pulse' all managed at the header (manifold)...after that, its nothing...only to silence the noise and remove poisonous gas as far as possible...
ixeo
4,788
3,080
KL, Malaysia
I think the current engineering marvel is the Mazda Skyactiv engines, that comes with optimized exhaust header/manifolds. Very good low end torque for a naturally aspirated engine, maybe you can google it up and read more about it? Lots of papers on it.
The easiest way to explain..is imagine your exhaust system is a straw
use a big straw, like those for bubble milk tea, and a small straw.. like McDonald's.
take a mouth full of water, and try to blow the water through the straw with full power, you will find that
1. with the big straw, the water will flow slower, i.e. shoot nearer but ALL the water release from your mouth very fast. in other words, the amount of time it takes for all the water to come out from your mouth is shorter
2. with the small straw, the water will flow faster, i.e. shoot further, but ALL the water in your mouth will release slower. In this case, the amount of time it takes for all the water to come out from your mouth is longer.
So 2 factors at play, flow & volume. you can say with small straw there's "backpressure" and with the big straw you lose "pulse or power". This is NOT a very accurate example, it is only meant to illustrate the difference between big & small exhaust diameter.
cvkit17
2,884
1,354
Pulse is like a sync between the cylinders to work as a system. Too short the pipe at low rpm, you will lose scavenging which will lower the engine efficiency.
Flow is volumetric rate lorh...I guess u mean flow and velocity? With a big straw, flow rate is higher but discharge at a lower pressure and vice versa. Bigger diameter, if the volume of air doesn't fill up the area of the pipe there is an expansion and it is bad if it is exhaust air because any expansion of air means lower pressure (the air itself) thus lower temperature hence lower energy to "move" or "travel".
Erm..back pressure is bad, but a bigger diameter pipe doesn't mean it is good even though it reduces back pressure. Pressure is built up when the friction (or static pressure, in tech term) is high. Let's say air reaches the silencer. The friction caused by the silencer is higher than the friction in the horizontal path. This will cause the air that reach the silencer to slow down but there is air keep on coming thus it pushes the air at the silencer and compress it. That is why pressure builds up. Just like you r in the bus and u r standing at the back, when there are more people coming in you are pushed and sardined. It's bad.
When you have a bigger diameter pipe, other than expansion of air causing the temperature to drop, the amount of air "exposed" to the surface of the pipe or extra space in the pipe will also cause the temp to drop. The conductivity of heat per inch pipe is larger.
ixeo
4,788
3,080
KL, Malaysia
Which is why I say its not an accurate example.. If I was that good I won't be here talking cock la.. I making rockets already...
cabutz.
esthapo
Trail Bomber
796
186
Sister'sBedroom
Its engineering not myth laa bro...
I know some of the guys feeling of maintaining 'back pressure & my car will accelerate like rocket' :rofl:
Waiora_ProTuner
619
221
i would go into entire lengthy discussion, but i need to go to work tomorrow.. :rofl:
best exhaust is NO exhaust..
-credit to AutoSpeed -
The idea that an exhaust has to provide a certain amount of back-pressure if best engine performance is to occur is a very strange. In fact, back-pressure will only increase pumping losses, leading to higher fuel consumption and lower performance.
The myth has come about because fitting a large exhaust on some cars has resulted in a decrease in power. But that decrease is nearly always because the engine is no longer appropriately tuned! For example, after being fitted with a big exhaust, MAP-sensed engine management systems may run leaner than optimal. Ignition timing is also likely to be no longer best for performance.
It seems obvious, but if you change the efficiency of an engine – eg by a major exhaust change – the original parameters for which the engine was tuned no longer apply. Therefore, if you want to be assured of getting the best results, you should factor-in an engine management retune at the same time as you get your big exhaust.
Having said that, in 20 years of modifying cars – including turbo and naturally aspirated - I’ve never seen power fall with a big exhaust.
And if you’re still a believer in back-pressure, just put a potato up your exhaust tip and see if performance improves...
AutoSpeed - Automotive Myths
Similar threads   Forum
Just like any brand new car, this Ford Kuga is no exception. We always tell our clients that even though your car is brand new and a few days old, it does not mean that the production date was a few days old. Most cars are stored in open air warehouses till the batch is complete. Prior completion of the...
